Help putting timer on my welder
Status
Not open for further replies.
Hi Guys,
Im looking at adding a delay timer to my mig welder, ( new welders come with this) I need it to be adjustable in sec, on for 1-10 sec and off for 1-2 sec, I would like it to work with the trigger on my welder. I see all kind of delay timers on ebay but not sure witch one would work, I would like one with dials just for easy adjustability but not necessary . I would put a switch in between the timer so i could have the welder in normal mode and switch it to stitch welding (timer mode) .The welder is 220v but if i cant fined a timer that works with 220v i can just run a different power supply for the timer.
Thanks for your time and help.
G
Stitch welding, yes you can do it with the trigger, but with a timer you get the same size bead each time.
The trigger switch more than likely operates currently on a low voltage so might be a good idea to find out what that is.
Reason being it may be a factor in deciding what voltage timer unit to buy.
One referred to above is 12v but there may also be others available e.g. 5v or 24v.
Not a bad idea though as a mod for your welder.
Just wondering about burn back times and whether this would be affected by the mod.
I will test that switch and see what i have. The welder that i used that had this option was awesome with no burn back. Thanks for your help!
G
Gunit,
What make/model MIG are you wanting to add the timer to. Sometimes there are block schematics for "major" brand machines. I read about "Spot" and "Stich" settings on MIGs. I'm curious because I made a pulser for a Miller TIG. It actually switches between high and low current pulses, as opposed to ON/OFF.
Ken
Hey Ken, I have the pdf , but thanks, yes cant be much current with the 14-16 ga wire that goes to the trigger, I just need a relay setup that will turn on and off that i will hook to the trigger wire, I just was not sure what relay would do it,( kellys_eye ) pointed me to one, its just in the UK need to find something in the US.
Thanks for your help.
G
Gunit,
From the photo, there two black, cylindrical ,electrolytic capacitors that are likely the timing capacitors. Replacing them with ones of less capacitance should proportionally reduce the timer ranges.
Ken
Status
