I'm hoping there is some nice person out there who will help a newbie. I'm trying to find a solution to supply a variable current to a coil which is directly proportional to a variable analog voltage as the input. The final application is control of a pair of galvos at high speed.
The input for this will be a 0-5V analogue signal from initially an Arduino (so 40ma). Programming is my thing so no need to worry about that... but how do I control the current rather than the voltage? I understand that transconductance ICs like the LM13700N would be great but 600uA isn't enough for powering a small electromagnet, I'd guess 200-500mA is more realistic.
The coil in question is indeed small, <2m of 27swg copper with a negligible resistance (0.2ohm). I'm using two of these in combination to displace a 10mm neodymium magnet which is attached to the shaft on which my FF mirror is attached. The total mass / inertia to handle is very small, but there needs to be no doubt about it shifting quickly, hence needing a good powerful current in the coil.
Please can you be sensitive to the newbie thing, the lower the component count the better
Many thanks in advance,
Tim
Tim
