HELP identifie rectifier values
Hi, I need help identifying the amps and voltage of the diode. I came off my welder I'm trying to fix but the part number on it comes up with nothing on Google search. I hope someone can help me out thanks in advance
Number on the rectifier 1504t2a27
Looks almost as if this is 6 diodes in parallel, it is obviously a Motorola part, if obsolete you could use stud mount types and make another bank up, is this a TIG welder?
M.
Are they in parallel or at least half and half?
M.
I don't think so it looks like their in series because all 12 diode bolt on to the aluminum plate.
I can find the diode on ebay but their rated at 25 amp and 200 v now I don't know what the ones I took out are rated at
MIG is not usually higher than 40-48v tops.
So it just the current that is the main concern.
If bolted to the same plate then it could be a parallel or set up in a bridge configuration, usually, but 6 is an odd number, It should be easy to work out how they are configured.
M.
Should be OK, The rectifiers would normally be on the secondary so the voltage should be alot less than 120v.
M.
