Help. Alternative Schottky Barrier Rectifiers
Hi Everybody,
I am a first year electronics student so I need some help on this one.
I have a PSU that is not starting. I have re-capped the supply to no effect. However, I have discovered a Schottky Barrier Rectifier that seems to be faulty. I can not measure continuity in any direction (part has been extracted). The original part number is SBR30150.
Datasheet here
Since I have never had to work with these components yet, could I get some advice on finding an alternative part to replace it?
I normally order from RS, Farnell or Mouser.
Mouser have them, but there's a 5 week lead time. If I could find a readily available alternative, that would be great!
It should match the original part because it is essentially the same device.
Yes, I would feel comfortable using it as a replacement.
