Platforms
Content
no is not home study, is just my hobby,this looks like a homework/study style question
I have moved it to that section
you will get guidance rather than outright answers
We expect input from you regarding what you do know/understand about the circuit![]()
It stores charge.what do the capacitor?
It stores charge.
What are you trying to do with that circuit?
to tell you the truth, nothing just i want to know, how its work, i know that in ac capacitor only discharge and charge, but i see in one site this and i was liking to know how it working, of this connection dont existIt stores charge.
you mean the capacitor dry the collector resistance?It stores charge.
you mean does not exsist such a connection?I wish I could help, but I have never seen a circuit like this. I have seen it in an npn circuit used for a signal ground.
I have never seen it on the load resistor in any circuit. Npn or pnp.
Good luck with this one.
yes i want to know how its workwell it is ion the style of homework, so we will treat it as such
1) where did you get this circuit?
2) how much of the operation of the circuit do you understand?
3) what google searching have you done to try and identify what may be happening in the circuit ?
here i getLooks like you're trying to simulate a common base circuit, but then R1/C1 need to go to a positive supply, not ground.
But I have no clear idea what C1 is good for. It will decrease the collector impedance for higher frequencies, thus lowering gain.
Are you trying to change the frequency response? It would really help to know where you git that circuit from. Obviously you haven't made it up yourself, otherwise you'd know what C1 is good for.
Is this article wrong then, Ratch? Q=CV, so for a given C the charge and voltage are proportional. Energy E = CV^2/2.No, capacitors store energy, not charge. A capacitor energized to 1000 volts contains the same net charge as one with no voltage across it.
Eh?you mean the capacitor dry the collector resistance?
Yepyou mean does not exsist such a connection?
There's one big difference: The original circuit uses a DC input source, not AC as you do.but i see in one site this
hear
