There are selfthreading metal screws that can just
be tightened....
Possibly better than heating square inches of copper.
Rene
Still not enough room. I've just got a little more than enough room for
the ~1.5 mm Sq pins of the Bus Bar, think of it as a rather large SIP.
Of course with self threading screws there also comes the worry of metal
fragments shorting out the rest of the circuit. Thread forming rather
than thread cutting helps on that.
For anyone who's still following along at this point I determined that
two irons together (well an iron and a gun) work quite effectively at
flowing the solder without overheating the rest of the board so I expect
that a large iron will as well. Three handed soldering is a bit beyond
my dexterity so if I need to do any before I get the larger iron I'll be
reduced to building up cold solder balls around the joint and then
applying the two heat sources at once.
I quickly tried the Weller with snipped tip forming a gap but without
much effect.
I'll be getting a large iron and keeping my eyes open for a cheap solder
pot/wave.
Robert
