R Adsett
I have an assembly that uses Cu bus bars 1.55 mm thick connected to a 3
oz Cu plane on PCB via through hole pins 1.5mm wide. So that gives pins
about 1.5 mm sq.
The problem I have is that with the iron I'm using at the moment the
combined heat sinking of the Cu plane and the Cu bus bar is too much for
the iron to overcome. I'm looking for something that would be
appropriate. I've used American Beauty heavy duty Irons in the past for
similar purposes but I'm wondering if any one has other (perhaps better)
suggestions.
Robert
about 1.5 mm sq.
suggestions.
Robert
