Heat a battery Sustainable energy
Hi
I am trying to find a thermal fuse with a 40c(or35c) open and 50c(or55c)close I can put on a lithium ion battery to keep the battery at that temperature range
It is for a sustainable heating project
Please tell me your thoughts if that's possible
I've read lithium ion batteries are recommended to be less then 55c when charging
Thanks for letting me ask
This project will help tremendously if it works
I understand it is not recommended and will not in anyway blame you if there are any problems that happen
<SNIP>
The use of a lithium-ion battery is possible in a temperature range of 10°C to +55°C. However, the charging should take place only at a battery temperature of +5°C to +45°C. The deal temperature range of the batteries is room temperature
Mederators note : removed email to avoid spam and privacy
Hi
<SNIP>
