I bought a headset a mere few days ago and already I am experiencing a major issue. If I connect my mic and my sound jack to my laptop at the same time, the mic doesn't work, or it works but isn't clear, or it works for a while but then stops working after a few minutes, or the sound output gets detected by the mic and is heard by the other person, but sometimes when I stick the jacks in and out and tinker with it it will work properly, but now it is just too unreliable, unstable, and too much of a hassle.
I don't know if the problem is crosstalk, my laptop, the design of the headset is wrong, or the design of the laptop is wrong, or if there is not enough voltage being supplied by the laptop because sometimes my usb devices don't work properly unless I connect them to a laptop via a powered usb hub (a usb hub with a plug to the outlet).
I wonder if there is some kind of shielding that I could maybe try to apply? Or maybe some kind of "powered jack input connector" for the headset jacks to ensure that it is getting the proper voltage.
Also, I have attached some pictures to show what I mean by the design of the headset or the laptop seems questionable. The way the mic jack is wired to the sound jack is weird, and the way the mic and sound are side by side is also weird.
Please could you help me?
