Hi experts,
I have a general aviation headset, the audio works well in both earcups, but the microphone is completely inoperable. Suspecting a bad solder joint, I pulled it all apart and did a continuity test from the plug that goes into the socket all the way through to the terminal on the microphone speaker and both sides look good (0.08 ohm resistance) I also tested resistance across the two terminals on the mic and it measures around 80ohm. My initial thought was the mic was stuffed, I did however wire the mic directly onto a 3.5mm plug and connect it to my pc, if i blew into the mic I could hear it, talking into it came out really garbled, I then did the same test with a known working headset (bare wires of the 3.5mm plug touched onto the headset jack) and it sounded exactly the same so now I am not sure it is the mic.
As I am running out of ideas, wondering if anyone has any suggestions on other tests I could do to see where the fault lies, also if anyone knows of a way I can properly test the mic so I can hear my voice clearly to completely rule it out without buying an expensive adaptor?
Also to note, this is a very cheap headset, it doesn't have any fancy noise cancellation and has a very basic circuit board which from what i can see just terminates the wires together. pic: https://imgur.com/a/tujtat4
thanks in advance!
thanks in advance!
