Paul E Bennett
Phil said:Hi, all,
I don't have much to contribute to the LCR MOSFET argument except
possibly some ethological insight:
<http://electrooptical.net/papers/TerritorialityInTheWhiteRhinoceros.pdf>
. But I digress.
I'm on a trip to SoCal to debug the pre-production models of my
spectrometer. The SNR is pretty good, way over 60 dB (which is good for
a SWIR spectrometer).
Looks like the last remaining problem is that the spectrum has a way of
sort of swimming around a bit, i.e. the gross shape stays roughly the
same, and the small scale noise is low, but there are small systematic
variations on scales of 1/10 to 1/2 of the scan range, where multiple
spectra don't quite line up with each other.
[%X]
Any additional wisdom on these things? We can rip out the encoder and
bodge in a pot if we have to, but it'll limit the instrument lifetime
fairly severely.
There are a couple of options for sensing shaft rotation. As someone else
already mentioned the optical encoder I will confine my response to
suggesting that you could use a Synchro/Resolver to monitor the shaft. These
can be quite accurate over fairly wide temperature regimes. The decoding of
resolver signals (Sin/Cos) is not that difficult and there are chips from
Analog Devices that will provide a digital output from the signals. You can
even get rate of rotation informtion from them.
Paul E. Bennett IEng MIET.....<email://[email protected]>
Forth based HIDECS Consultancy.............<http://www.hidecs.co.uk>
Mob: +44 (0)7811-639972
Tel: +44 (0)1235-510979
Going Forth Safely ..... EBA. www.electric-boat-association.org.uk..
