JosephKK
My past winter (2007-2008) ("mid-atlantic" eastern USA) came in warmer
than average of the prior 3 calendar decades.
Vastly different locale. I was comparing notes with my "neighbor"
less than 50 miles away.
It's how they do that 'smoothing' that strikes me as highly suspect.
Something not dissimilar involving stuff called PCs, that are a bit over my
head so far (until I really study it up) is what created Mann's hockey stick
(now wholly discredited by the IPCC).
If the 'science' and maths/statistics is THAT weak WTF are we doing worrying
over it ?
In the meantime we have a REAL energy shortage (oil) of some note, the
simple solutions to which such as energy efficiency would fix not only that
energy crisis but ameliorate any concerns about the role of CO2 in the
atmosphere too.
PV Solar is getting cheaper as the volume of production ramps up - at
the moment it seems to be conforming to the usual rule that a ten-fold
increase in production volume halves the unit price. See
Richard said:When you don't know what you are talking about, you should just keep
quiet. People can tell.
JosephKK said:Not an actual shortage, but huge price increases.
Ummm....
<http://scholar.google.com/scholar?q="global+warming">
184,000 papers on "global warming" and:
<http://scholar.google.com/scholar?q="climate+change">
760,000 papers on "climate change".
<snip>
Utter nonsense. It's been at around $6 per peak installed watt for ages.
Well, perilously close to a shortage at current production and use levels. What
would a really cold winter do ?
We have a device suitable for a "brain boost". It's an AC power cord
with alligator clips. Grab on, plug in, light up. It's also called a
"suicide cord". It will either elevate your IQ, or kill you. We're
still working on this problem and other bugs.
I can see why Europeans are smarter than Americans. Their "brain
boost" runs on 230VAC instead of 117VAC.
Incidentally, the technology for the "brain boost" device was
delivered by extraterrestrials in 1956 and documented in the movie
"Forbidden Planet" where Lt. Ostrow gets a fatal IQ boost from the
Krell original.
I have some bad news for you. The revised testing methods have
created a different score distribution. 100 is the median score
(Wechsler Scale) which tends to change somewhat with populations and
testing methods. See:
<http://en.wikipedia.org/wiki/Iq>
<http://wilderdom.com/intelligence/IQWhatScoresMean.html>
My guess(tm) is that you took the Stanford-Binet test. A score of 144
converts to 141. My 135 converts to 131. I'm used to dealing with
depreciation.
Interestingly, I later took the original SAT test in about 1969 and
scored about 1250. That converts to the same IQ of about 131.
<http://www.iqcomparisonsite.com/Pre1974SAT.aspx>
Graham
Most managers I know would barely rate 90 on a good day.
One ignores then as far as possible and if in doubt tells them what to do. That
usually shuts them up.
Says someone who believes in AGW !
Ummm....
For 2008 alone, there were 10,400 papers on climate change. I can
read/skim about 1 pager per minute. The 10,400 current papers, at 8
hours reading per day, would take me about 22 days. The 2007 readings
would take about 78 days. Reading all 760,000 papers would take 4.4
years of continuous reading at 8 hrs per day.
Perhaps you might suggest a less Herculean task?
Just fun, from Google Scholar limited by year of publication:
Year Papers mentioning
"Climate Change"
2008 10,400 (to June 10, 2008)
2007 37,300
2006 34,700
2005 32,400
2004 27,600
2003 25,400
2002 22,100
2001 19,500
2000 15,400
1999 12,300
1998 9,820
1997 8,100
1996 7,100
1995 6,110
1994 4,380
1993 4,120
1992 3,450
1991 2,470
1999 2,000
And in 1978, I complained that 16k DRAM chips had been stuck at twenty
quid each for ages.
The decline in unit price as volume increases isn't a smooth,
continuous function - it goes in steps as someone discovers something
new or thinks up a better way of making something familiar. Think
about the amount of money that has been invested to keep up with
Moore's Law.
Richard said:Yes, but $6 isn't what it used to be
Encourage people to get on with exploiting the Athabasca oil sands.
http://www.theoildrum.com/node/3839
Impressive. As I recall, I was recovering from a cold or flu when I
took the test. The antihistamines probably cost me a few points.
I've considered putting my IQ, diplomas, and grade point averages on
my business card, but there's no room due to all the email addresses,
phone numbers, and web sites. I plan to add a bar code strip (code
39) on the back for easy address book entry. Too bad Outlook doesn't
have a field for IQ.
You mean like me?
Not developable fast enough.
So what do yiou have against my infinitely more sensible idea of installation super
insulation in all homes, offfices etc ? Which addresses energy use AT SOURCE.
So what do you have against my infinitely more sensible idea of installation super
