Jan Panteltje said:
I have my EM-411 GPS module working on Raspberry Pi.
The module was something like 25 $, and the Pi maybe 35?
It runs linux and you can do NTP too if yo uwre connected to that
thing called 'internet'.
You don't have to have an Internet connection to run NTP on Linux
(ntpd). ntpd can get a time reference from two kinds of sources. The
first kind, which is the way most people with desktop Linux machines
probably use, is some other server that is accessed over a network
connection (local or Internet). The second kind is an external piece
of hardware that is directly connected to the machine running ntpd: a
GPS/GLONASS receiver, a WWV/DCF77 receiver, an atomic clock, etc. This
second kind is less common, but is how all the public time servers
eventually derive their time.
I dunno however if you get the time via NMEA serial out at 4800Bd, how
much the exact offset of the time field in the NMEA is versus any real
time.
As I understand it, the way ntpd does it on Linux, the 1PPS output from
the GPS receiver is connected to one of the flow control lines on the
serial port. When the 1PPS output goes high, the kernel is able to
report the time it went high to ntpd. ntpd compares that timestamp to
the previous one to decide if the system clock is running fast or slow,
and steers the system clock accordingly.
The NMEA data from the GPS receiver comes through the "normal" RxD line
on the serial port, and gets parsed to find out *which* second of the
day it is. The reference for *when* the second starts is the 1PPS
signal.
Most GPS modules will have some specification about how soon the NMEA
data starts being transmitted after the 1PPS pulse, but as you noted,
it takes time to receive and parse the NMEA data. This extra time
probably doesn't make any difference if all you want is 1-second or so
accuracy, but if you need finer resolution than that, you need to watch
for the 1PPS signal.
If you are playing this game, you should also know about leap seconds.
Basically, there is an offset between the time the GPS satellites report
and UTC, currently 16 seconds. The current offset is transmitted in the
GPS data stream, so it is possible for a GPS receiver to give you GPS
time or UTC time; you have to pay attention to which one you are asking
for and/or getting.
Every so often, this offset is increased by 1 second. Once every couple
of years, the time as reported by a GPS receiver in NMEA will count
23:59:58, 23:59:59, 23:59:60, 00:00:00. If your parser isn't set up to
accept 60 as a valid second, or if you've implemented your own clock-
steering algorithm based on GPS data, your software can get very
confused very fast. (It's also possible for there to be a negative leap
second, which I think is done by skipping 23:59:59, but I don't think
this has happened since GPS service started.)
Matt Roberds
