Yep. The time between pulses is guaranteed to be exactly 1 second.
However, the time of any particular pulse is NOT guaranteed to be
synchronized with any particular time or event. If you take two GPS
receivers, and compare the 1 pps outputs, they could easily be at
quite different times. However, each succeeding pulse will be exactly
1 second later.
Sure. Get a receiver that is suitable for running a clock, not an
interval timer. The complexity and cost will depend on how accurately
you're trying to sychronize. Lacking numbers, I can't offer any real
solutions.
Maybe something like this will work:
http://www.gpsclock.com/specs.html>
"The GPSClock 200 has an RS-232 output that provides NMEA
time codes and a PPS output signal. About a half-second before,
it outputs the time of the next PPS pulse in either GPRMC or
GPZDA format. Within one microsecond of the beginning of the
UTC second, it brings the PPS output high for about 500 ms."
If you can live with some atmospheric and propagation drift, the
cheapest solution is a WWVB 60KHz receiver and clock.
http://tf.nist.gov/stations/radioclocks.htm>
The problem is that WWVB only works in North America.
Jeff Liebermann
[email protected]
150 Felker St #D
http://www.LearnByDestroying.com
Santa Cruz CA 95060
http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
