if there are consumers nearby without solar and using energy - it
would
Remember too - about the "feed in tarriff". in the QLD system, it is
only paid on power IN EXCESS of what you are using in your own home.
So if you are using 0w and generating 1kw - you will be paid the feed
in tariff on the 1kw x the number of hours it is generated.
If you are using 500w and generating the 1kw, you are paid 50% of the
feed in tariff PLUS saving the normal tariff of the 500w you are using
in your home.
If you are generating and using the same amount, then you are only
saving the normal tarriff, which is a LOT less than 60c (typically 17c
for domestic and half of that for off-peak hot water - if its actually
on at that time.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If you arent going to be home during the day, and can turn off all
appliances in the home during that time - including hot water systems,
and all things that use stand-by power - you will get the full 60c.
You may be able to get away with turning the fridge off during some or
all of that time, if the insulation is good, no one will be home to
open it, and you don't have anything that is going to spoil at the
slightest drop in temp. (IE beer fridge in workshop) Whether this is
worthwhile compared to the savings is another matter.
As to your other question, if the power being generated isnt being
used, it isnt stored anywhere.
Its the same scenario as a generator running without load, or a better
analogy would be a battery that is not connected to anything.
With no load, the impedance of the power lines would just rise
slightly and the power from the solar system simply wouldn't flow into
the grid as there would be no load for it to flow into. Whether the
solar system generates a slightly higher voltage than the mains
voltage - to get it to flow in and therefore "take priority" over the
mains, for any load on the grid that is below the solar panel's full
output capacity - I don't know.
The inverter in the solar system might even just shut itself down,
until there was a load present ?
