Robert Baer
Does not work.
"Procedure entry point freeaddrinfo not found in WS2_32.dll"
Does not work.
I use Win2K, with the latest roll-up (made it SP5); this Baer growlsLasse said:Den tirsdag den 19. november 2013 00.30.36 UTC+1 skrev Robert Baer:
usually means the dll is an old version from before that function was added,
you wouldn't happen to be running some ancient OS that hasn't been or can't
be kept updated ?
-Lasse
Does not work.
I do not speak "C" and we do not get along with each other, so cannotTo execute an application using this function on earlier versions of Windows (Windows 2000, Windows NT, and Windows Me/98/95), then it is mandatary to #include Ws2tcpip.h and also Wspiapi.h. When the Wspiapi.h header file is included, the 'getaddrinfo' function is #defined to the 'WspiapiGetAddrInfo' inline function in Wspiapi.h. At runtime, the 'WspiapiGetAddrInfo' function is implemented in such a way that if the Ws2_32.dll or the Wship6.dll (the file containing getaddrinfo in the IPv6 Technology Preview for Windows 2000) does not include 'getaddrinfo', then a version of 'getaddrinfo' is implemented inline based on code in the Wspiapi.h header file. This inline code will be used on older Windows platforms that do not natively support the 'getaddrinfo' function.
Microsoft KB article http://support.microsoft.com/kb/955045
Found via Google as "I Feel Lucky" in 0.01 seconds.
OOPS!Robert said:I do not speak "C" and we do not get along with each other, so cannot do
a "build" as you seem to imply.
I poked around and 2.2 works.
Thanks.
that is as far as it goes in updates.
Gerbv-2.4.1 has same exact problem.
So, is that dll available for Win2K, or is there a version of Gerbv
that will run in Win2k?
Thanks.
John said:You should consider upgrading to a modern OS, like Windows XP.
Has not support for that just ended?
I cannot use all of the functions of my computer with XP or "better"John said:You should consider upgrading to a modern OS, like Windows XP.
Ask Microsoft; they create crazieness with their ugly OSes.Jasen said:possibly if you compile it yourself. OTOH I don't recall it having any
network functionality, I wonder what it needs ws2_32 for.
See my other response WRT XP.Jan said:Has not support for that just ended?
April 8, 2014 for both XP SP3 and Office 2003. I don't expect it will
suddenly stop working on April 9.
it won't stop working but newly found security hole will not be closed,
so yeh, it will probably be april 10 before they all become part of a botnet
only hope is that it becomes rare enough that no one bother to find any holes
-Lasse
because there are no drivers for the video capture card, or the sound
card, or the Ethernet card, or USB functions for my flatbed scanner or...
I am not about to throw away hundreds of dollars of perfectly good
hardware JUST for one or two stupid programs.
Den tirsdag den 19. november 2013 12.04.46 UTC+1 skrev Spehro Pefhany:
-Lasse
SCADA??? With all of the bugs and malware running around??? Are youjosephkk said:Actually yes you are. Maybe not today but eventually when nobody can find
or create a machine that will run the antiques. And by the way, they have
depreciated below zero value already. You will have to pay someone to
haul them away for you, especially since they are already effectively
useless. Get used to donating your old stuff while it still has value.
And if you need real longevity look as buying SCADA oriented hardware; 19
times the price of ordinary stuff; your choice.
crazy? Telling me to jump from the frying pan into the fire?
