Robert Baer
To use in my modern Windows 2000 Professional SP5.
Robert Baer said:To use in my modern Windows 2000 Professional SP5.
If you're interested, I can send you a set of 2 DLLs (along with sources and
install instructions) that allow the latest gerbv (as well as any other
program that needs the getaddrinfo / freeaddrinfo / getnameinfo functions
exported from ws2_32.dll) to function under w2k.
With some programming skill, you could extend them and add other functions
(even to other dlls) as needed. The sources are no secret, but you'd still
have to look for specific versions of certain compilers, assemblers, linkers
and resource editors in order to recompile them as they are highly
non-portable.
The installation is also a little tricky, it includes renaming and
*replacing* the original windows 2000 ws2_32.dll by a special "loader" dll
that would load the original (renamed) dll as well as another one that
provides the "missing" functions and arbitrate at runtime which functions
shall be used from which of the modules (original with all the MS code or
the additional one with just the 3 new functions).
To the applications it looks as if the original dll had always included
those functions and as if they had always been there, part of w2k. In fact,
unless the application tries to read and parse the dll's contents from disk,
it has no way to tell that the 3 extra functions are not "just a normal part
of w2k".
There's a caveat however: this dll module, once it is installed, works
systemwide, and not just for any special program like gerbv. Every program
(including winlogon and all other windows internal processes and services)
will see the new dll. It's an "either-or", there's no way that I know of, to
load the new dll into one program, but somehow skip it and not load it into
another, different program.
It works on my small test system (gerbv works and nothing crashes), but I
don't have all the programs that you have, and, even though the loader
mimics the original windows dll fairly well, there may be some program you
have in use that will find something amiss and stop working.
Also, even if the dlls were perfectly and indistinguishably compatible,
which of course they are not, replacing system dlls via the command line in
safe mode always has some risk of making a typo and putting the wrong dll
into the wrong place by accident, with the obvious consequences.
Greetings from a fellow don-t-even-ask-me-about-vista oldtimer
Dimitrij
Color me confused.Maynard said:I find it hard to believe you're having that many problems with
getting that working..
Did you remove/rename the DLL's in the local folder to make sure it
isn't loading the wrong one? I assume you have what you think is the
correct DLL in the system32 folder?
Jamie
Not only sounds tricky, but messy and sneaky.Dimitrij said:If you're interested, I can send you a set of 2 DLLs (along with sources and
non-portable.
of w2k".
Dimitrij
Wish i knew what that all means..Maynard said:WHy not a proxy DLL that is loaded in the local folder of the app? Just
call it the same name so the app will see that one first and load it.
In this DLL, you load the real DLL using the full path name to get the
one sitting in the system 32 folder.
With this DLL, you need to make proxy entries for all the calls over to
the real DLL and implement the ones that need to be added for this app!
(P.S.) I've done this before, also This is how I found undocumented
functions in windows DLL's it is also how hackers redirect your system
if you aint watching!
Jamie
I stole the XP version of ws2_32.dll from XP and got yet anotherRobert said:Color me confused.
I downloaded the latest version and that installed.
Launched it and got message procedure entry point freeaddrinfo could not
be found in ws2_32.dll .
I have not moved or renamed ANY dll, and there is ONLY ONE, and that one
is "native" to the installation - meaning i have not replaced it or
buggered it.
So, now what?
error procedure entry point ntdll.dll could not be found.
And stealing the XP version of ntdll.dll changed nothing for gerbv.
Why not an OLD version of gerbv (which i originally ASKED for)?
Robert Baer said:Not only sounds tricky, but messy and sneaky.
Well, i am willing to give it a try; will use a spare HD.
Safe mode?
In my older installs of Win2K,"SafeMode" was totally and absolutely
useless. Maybe with this newer install, it will work because i do not have
other OSes installed.
Perhaps the scheme could be patched to look for the calling program and
then switch to what was needed for the calling program (based on a list
easily modified externally)?
If not in the list, then works exactly like original ws2_32.dll via a
call to it; else call to a differently named program(s).
!CHECK!!!!!Martin said:Try Viewmate from pentalogix.
Jamie
Robert Baer said:Why not an OLD version of gerbv (which i originally ASKED for)?
I appreciate all of the work you have done, but..Dimitrij said:Hi Robert and Jamie
These dlls were written before Jamie posted the info about dlls in the
program folder taking precedence. What is included through the link below,
are the original dlls before Jamie's post, although there are more
installation options available now. For details see below.
http://home.arcor.de/dimitrijklingbeil/WS2_32_2000.zip
What you should get, is a Zip file called "WS2_32_2000.zip" with size
45.495 bytes. Inside WS2_32_2000 are 2 folders ("WS2_32" and "WS2_32_USR")
with one dll and its source code in each. The dll's CRC32 values are
"7C2EFEA3" and "D18F7C98" respectively (just in case you like to verify).
The compiled dlls are provided for your convenience, but you can rebuild
them from source if you like. The CRCs will change because the linker puts
the build timestamp in the file. Depending on if you choose one-pass or
two-pass assembly, or other optimizations, the size can change slightly.
Skip the following sections if you don't intend to recompile from source.
To recompile "WS2_32", you need Borland Turbo Assembler (TASM) 5.0. Use the
32-bit assembler and linker, TASM32 and TLINK32 respectively. Set case
sensitivity to "all" (/ml option) for TASM32. Set module type to "dll",
case-sensitive, application type to "windowing compatible" and base address
to "74400000" (-Tpd -c -ap -B:74400000 options) for TLINK32. Link with the
provided "def" and "res" files as well as the "import32.lib" that comes
with Turbo Assembler. The res file can be edited with any suitable resource
editor (e.g. Borland Resource Workshop).
Note that Turbo Assembler is from 1996. Borland has stopped selling and
supporting it long ago. In its days it was sufficiently popular and today
it is sufficiently ancient, so that many abandonware sites have copies.
To recompile "WS2_32_USR" you will need Microsoft Visual C++ Toolkit 2003
and Microsoft Platform SDK for Windows Server 2003 SP1. Use the "Windows
2000 Build Environment (Retail)" from the SDK and inside that command window
call "vcvars32.bat" from the C++ toolkit to set up the build environment.
Then change directory to where the dll sources are and call the included
"compile.cmd" to compile the dll.
Anyway, once you have the dlls (the included ones or the ones you have
compiled yourself), there are two possible ways to install them.
Thanks to the hint from Jamie about dlls in the program directory having
a higher priority in the load order than the ones in %windir%\system32,
it's also possible to install them for a specific program only. Sure enough,
it should look trivial, and it's usually the trivial things that one tends
to forget, but when writing these dlls I did not remember the load priority
and had at first assumed that "system32" gets higher priority. Thanks Jamie
for pointing that out.
Although the dlls have originally been written for system-wide installation,
I've just tested Jamie's idea, and it turns out that they work for a single
program (gerbv) just as well. There was even no need to change anything in
the dll code, it turned out to be universal enough to allow both ways of
installation. Here are both instructions, for the sake of completeness.
Both are possible, even though you'll likely only want the first one.
1. Installation for one program (gerbv) only (Thanks Jamie!):
a) start windows normally, no safe mode needed
b) find the original WS2_32.dll in the WINNT\SYSTEM32 directory
c) make a copy of it, name the copy "WS2_32_SYS.dll" (note that the
filename is hard-coded, the name must be exactly as written)
d) put this copy (ws2_32_sys.dll) into the gerbv program directory
e) put the 2 new dlls (ws2_32.dll and ws2_32_usr.dll) from the zip
archive (or the ones you compiled) into the gerbv directory too
f) now in the gerbv directory there should (among others) be 3 dlls:
- WS2_32.dll (your own or from the zip file)
- WS2_32_USR.dll (your own or from the zip file)
- WS2_32_SYS.dll (copy of the windows original "WS2_32.dll")
if any are wrong or missing, you'll have plenty of opportunities
and retries to correct mistakes whenever you like
g) done, gerbv should now work
2. System-wide installation (as was intended before Jamie's info)
a) start windows in "safe mode with command prompt" (otherwise
windows file protection won't let you rename and replace the dll),
log in and wait a couple of minutes until all services have started
b) change into the \WINNT\SYSTEM32 directory
(I will list the following commands in quotes, but don't type the
quotes into the command prompt, type in only the commands inside)
c) run "sfc.exe /cancel"
(it will say something about changes applied on next restart)
d) run "sfc.exe /purgecache"
e) run "rename WS2_32.dll WS2_32_SYS.dll" to rename the original dll
(note that the name must be exactly as written)
f) copy the 2 new dlls (ws2_32.dll and ws2_32_usr.dll) from the zip
archive (or the ones you compiled) into the WINNT\SYSTEM32 directory
g) run "copy WS2_32.dll .\dllcache\" to put a copy into the dll cache
h) run "dir ws2_32*.*" than take a good look and make sure that there
are now the following 3 dlls shown in the system32 directory:
- WS2_32_SYS.dll (the windows original that used to be "WS2_32.dll")
if any are wrong or missing, correct the mistake NOW, any mistake
that gets overlooked will make the system unbootable and fixing it
will be difficult (only possible to boot from the installation CD)
i) press ctrl-alt-del, log off, and reboot
j) done, any program that needs the 3 new functions should now work
Make sure you only use ONE of the installation options, not both together.
If gerbv still does not work, it's probably also missing gdiplus.dll from
microsoft. A "fresh" windows 2000 installation does not have it, but if MS
office is installed, it will already be there. If you don't have it, get
the "Platform SDK Redistributable: GDI+" from the microsoft download site,
extract it, and put gdiplus.dll from the "asms\10\msft\windows\gdiplus"
directory into your WINNT\SYSTEM32 directory. That should fix gdiplus.
Regards
Dimitrij
!CHECK!!!!!
Naturally, Viewmate install had a problem in that the URL for the
.NET install was incorrect; customer service (!EXCELLENT!) gave:
ftp://ftp.pentalogix.com/FreeUtilities/DotNET2/dotnetfx.exe .
And i am a free user, so that says a lot for their customer service.
Also, of all of the Gerber viewers, it is the ONLY one that shows my
logo (like on a final PCB).
What i think as impressive, is that it supports 255 NAMED layers;
just name them as in Eagle and all is spiffy!
It is well worth PAYing for!
There is one niggle, there are so many tools on the screen, that the
workspace leaves a lot to be desired.
Perhaps they will fix that (i made comments and generic suggestions).
Perhaps that reseller link will encourage them in spiffing up theirMartin said:I see they're a reseller for Eagle now. I didn't notice that last year
when I downloaded the new version of Viewmate.
Cheers
