Hi all:
I'm a mostly wood DIY-er and audio engineer, but have not used a soldering iron for much more than audio connectors over the years. I have attached a rudimentary drawing of a circuit.
We bought a pair of motorized pan and tilt heads for remote control of cameras for live streaming. They have a small joystick that sends + and - 0 to 12vdc on two pair cable for the two bi-directional variable speed 12v motors. They work great on wide shots, but are difficult to adjust on tight shots as the joystick is too coarse. Project idea is to compliment the 12v main feeds with a low voltage fine adjustment circuit.
I'm trying to brainstorm a way to send low voltages (.01v to 1v) to the motors as a fine adjustment. Thinking of the design (attached) with two AA batts in series with one motor side connected between the batteries and the other on a wiper of a center-tapped pot. That gets positive and negative to the motor, with a center "off." Aside from wondering what value the pot should be, my biggest concern is that the batteries would always be looking at the resistance of their half of the pot, and would constantly leak current. Getting very controlled low voltage to the motor would be solved, until the batteries drained. A switch to open the circuit could work, of course, but the batteries would still drain significantly when it was activated (standby?), even if the wiper never left the center tap.
Any ideas would be fabulous.
rcarbaugh
rcarbaugh
