Finally, Death of the 3.5 inch floppy disk
Joerg
Stuart said:
The AUTOEXEC.BAT no less? :)
Yup, pretty much, a batch file :)
DOS is so remarkably fast. No grding on hard drives, no wait, it's instant.
Andrew Smallshaw
Good grief, and here I was thinking Microsoft _finally_ got around to
fixing that. (I mean, cripes... at least look at a flaming CD
fellas?!)
That can create problems in the truly general case. Think about
it: you are loading drivers for an HBA and want to get them from
a CD-ROM, potentially attached to that very same HBA...
I think USB could be difficult due to the fact that the initial loader
(in the case of Windows XP and earlier) started in DOS, loaded the
drivers into RAM then kickstarted the NT kernel from there, but one
would have thought that on modern systems, the BIOS should still at
least allow some access to USB drives. And clearly CD-ROMs are
accessible as it loads the rest of the drivers that way.
That would seem the most natural PC way of doing things. I'm not
really familiar with the Windows boot process anymore but there
has to be _some_ point early on where the BIOS is still readily
accessible and kernel modules can easily be loaded.
Of course the most elegant way would be to place basic get-you-home
drivers on the device itself. Sun managed this twenty years ago
with their OpenPROM system, and that didn't even depend on the CPU
since they were written in architecture-independent Forth. However
that probably requires the kind of centralised planning and
authoritative "this is the way it is going to be done" assertion
that is difficult to enforce for commodity x86 hardware. The only
time I can see you doing it is with a new bus standard: if e.g.
PCIe had demanded it manufacturers would have little wriggle room.
Dombo
That was originally the intention with the IBM PC, e.g. the video card
has its own Flash or (EPROM in the old days). Unfortunately it works in
real mode only, and standardization for the software interfaces appears
to have stopped around 1988. The elderly among us probably still
remember Ralf Browns interrupt list.
Meindert Sprang
Dombo said:
... The elderly among us probably still
I still have it on my server. The windows version (help file) even. But
resent the word "elderly" :)
Meindert
SG1
Meindert
OK geriatric
Jasen Betts
There is a way to merge drivers ioto a windows install CD image, (
obviously this required writing a new CDR) AIUI microsoft calls it
"slipstream"
I think ACPI is something like that.
--- news://freenews.netfront.net/ - complaints: [email protected] ---
