Platforms
Content
What's the story with your scope Steve? Did you fix it?
Can you set up a permanent filter/notification on eBay? So if one comes up in future, you'll hear about it?Well, I spent some more time looking for the manual... And I couldn't even find one for sale.
Great Idea Kris! I'll have to do that.Can you set up a permanent filter/notification on eBay? So if one comes up in future, you'll hear about it?
Not necessarily. The scope responds to signals that it measures relative to its 0V rail, which is connected to its case, and to the earth pin on its power plug. That is then supposed to be connected to the soil through the mains earth and the earthing stake at the house, and the house itself (which is at least partly conductive) should be at roughly the same potential.Then I placed my hand on top of the scope so I would be grounded and the rest of the noise disappeared!So was the carpet the problem after all?
OK, that makes since.Not necessarily. The scope responds to signals that it measures relative to its 0V rail, which is connected to its case, and to the earth pin on its power plug. That is then supposed to be connected to the soil through the mains earth and the earthing stake at the house, and the house itself (which is at least partly conductive) should be at roughly the same potential.
But if there's a break in the earthing of the scope, and the scope's case and 0V rail is coupled to the mains voltage and/or some interference source through capacitance and/or leakage resistance, the scope will "see" interference and hum on things that are actually properly earthed. If you connected the probe to a wire out your window to a stake driven into the ground, it would show that hum and noise.
How would I do that? Is there some sort of equipment I would need?So you should check the earthing system of your house,
When I did that I got about 0.3 ohms. Is that what's expected?and check for continuity from the scope case to the earth pin on its power plug.
So does that mean the scopes just peachy?Yes, 0.3Ω is pretty much a direct connection.
Well I don't know where our ground rod is, and my Dad does not either... So I guess I can't do those checks.I'm not sure what to suggest regarding checking your home earthing system. I guess, start by finding the earth stake and inspecting it visually. Then get a long piece of wire and attach one end to the stake, take the other end to the room with the mains socket, and check resistance from the earth pin on the mains socket to the wire. (You might want to check for voltage between them first, in case there's some high voltage that might damage the meter on ohms range.)
Would it be OK to do that without knowing if it is earthed right?If the socket earth is properly earthed, stand on your carpet in bare feet, and measure AC voltage between your body and the mains socket earth pin.
When I did that I saw a 60Hz sine wave with a greater then 1MHz sine wave superimposed on it.Use your scope to look at the interference by just holding the probe end. Adjust the timebase and try to find out the frequencies of the signals it picks up. Some will be at 60 Hz I guess. There may be some at 120 Hz too. And it looks like there's something at a higher frequency. Try to identify the source(s). If there are any appliances nearby, try turning them off, unplugging them, or pulling the fuse or popping the circuit breaker for them.
Aggh! I cringe at the thought of spending all that money on a service call.Otherwise, get an electrician to do a proper check. Also you could try to find a forum used by electricians (rather than electronics people) and ask there.
Yep.So does that mean the scopes just peachy?
It might be a good idea to find out. It's important for the safety of everyone in the house. Over here, they're usually just outside an outside wall, or possibly under the house somewhere near the switchboard, if you have a crawl space.Well I don't know where our ground rod is, and my Dad does not either... So I guess I can't do those checks.![]()
Yes, that's safe, if you have a digital multimeter with high input resistance (they're usually 10 MΩ). That will limit any current that might flow.(re measuring voltage between your body, standing on the carpet, and the wall socket ground) Would it be OK to do that without knowing if it is earthed right?
Are you near any AM radio transmitters?When I did that I saw a 60Hz sine wave with a greater then 1MHz sine wave superimposed on it.
Good idea!Aggh! I cringe at the thought of spending all that money on a service call.I think I will ask on a electricians forum!
OK, I will do some research and ask around and see if I can't find out.It might be a good idea to find out. It's important for the safety of everyone in the house. Over here, they're usually just outside an outside wall, or possibly under the house somewhere near the switchboard, if you have a crawl space.
Well I checked, and my meter does have a 10MΩ input resistance. So I measured it and got about 1VAC.Yes, that's safe, if you have a digital multimeter with high input resistance (they're usually 10 MΩ). That will limit any current that might flow.
There's a broadcasting station about a mile away... I don't know if they do AM or FM or both though.Are you near any AM radio transmitters?
This is getting outside my experience.
I was thinking on this and why would am I only seeing that noise on the signal when I'm adjusting the probe compensation? If there was something on the ground wire, wouldn't it appear on all the waveforms I'm measuring? Regardless if I was adjusting the probe compensation or not.
That makes since.This is conjecture, but I would expect that the side of the capacitor connected to the adjustment screw is likely to be grounded. If the ground is floating, any signal injected here will not be be shunted to ground.
Unfortunately, when I did that I couldn't see any difference in the noise level.An interesting test would be to hold the scope probe in your hands touching the tip so the scope displays the noise, then move about the room (within the limits of the probe cable's length of course) and see how the noise increases or decreases depending on where you are.
OK, I understand.You need to understand that the scope measures the signal at the probe tip RELATIVE to its 0V rail, which is connected to its chassis, and to the earth pin on the mains plug (which you've already verified). (It's also connectd to the earth clip on the probe.) So if you touch the probe tip and get an indication on the scope, this indication will consist of signals your body is picking up that are relative to earth, AND signals that are present on the scope's chassis if it's not perfectly earthed.
I went around the house unplugging stuff and then looking at the 'scope, but I couldn't get anything to affect it. Not even the microwave.For example if there's an appliance that is injecting noise into the earth conductor in that room (the appliance need not be in the same room, because mains sockets are daisy-chained), the scope will show that noise, even if the probe tip is perfectly earthed.
This is why I suggested earlier that you should look for all appliances in the house that use significant amounts of power and/or could generate interference and turn them OFF individually to see what effect it has on the scope display.
I think that I have a good nohow of how the 'scope works... But then again, I have been wrong a lot before.You really just need to understand what the scope does, then try any experiments you can think of to try to determine the nature and the source of the noise components.
