Peabody
I have a radio trigger for off-camera flash, and would like
to extend its range. It's the CowboyStudio NPT-04, which
is dirt cheap and works very well, but the range is only
about 25 feet.
I found a blog post showing a mod to a similar 433 MHz
device:
http://jerryphpics.blogspot.com/2008/07/004-cactus-v2s-modifications.html
He added a 1/2 wavelength antenna, but it was wound into a
coil. Apparently the mod was very successful. I don't
understand why the coil works.
Mine is a little different. It appears that part of the
antenna is formed of circuit board traces, and then there's
a 1.5" length of wire soldered to that.
I've posted photographs of this in:
alt.binaries.schematics.electronic
with Subjects beginning "CowboyStudio". But note that I
screwed up the post the first time, so download the
articles with the usual yEnc format.
The device broadcasts at 433 MHz, and I can't make sense of
the measurements I found - shown in the pictures.
Item A in the pictures appears to be a capacitor (no
continuity with my meter).
Item B is just a plated-through hole with nothing but
solder.
Item C appears to just be a jumper (near zero ohms).
Then as you'll see in the bottom pic, the C-to-D trace is
duplicated on the bottom of the board. I assume that's
significant.
Then at D the wire is soldered.
So I was thinking of replacing the wire with a coil like the
other guy used. I could just try different lengths, but I'd
like to understand what's going on - what ought to work.
Also, I wonder what complications might be introduced if I
do succeed in extending the range. Will the transmitter
use more power from the battery, or would the extended range
be "free"? Might there be impedance mismatches that would
tend to overload the output transistor and burn it out?
Well, this isn't really important, but if anyone would like
to look at it and offer comments, I would appreciate it. As
must be obvious, RF is not my strong point, particularly
antennas.
about 25 feet.
device:
solder.
significant.
antennas.
