Experiment Platform for the MC68000
For fun, I am resurrecting an old MC68000P on a breadboard. I've never designed a computer system from scratch before, so to start I hooked the 68000's address and control lines to some I/O from a PC-104 card on a 200MHz Linux computer. The program initializes the I/O pins, and then runs through a state machine to properly communicate with the chip. First the processor's /HLT and /RST lines are asserted for 1/2 a second to reset, then released. Next the card waits for the 68000 to assert its /AS. Upon seeing that, the card sends a /DTACK. And then it releases /DTACK once /AS is negated. The data bus is hard wired with pull-up/down resistors for a 'branch-back-to-itself' instruction. Now the problem...
I can start the processor and, after a few clock cycles, the processor does 2 16-bit read cycle to fetch the SP. Next it should read 2 more for the PC. But instead it hangs without ever asserting /AS again to start the next bus cycle. I made a number of minor timing changes, with no improvment. Also I notice that the behavior is not always consistent, with a bus cycle starting without the Data Strobes being asserted. (Maybe timing irregularities from the Linux board?)
I read in the documentation that there is a minimum clock frequency for the chip (that I am certainly violating) and that the clock signal must be square (which I am crudely approximately). Do clock irregularities really matter in a static processor?? If I run off a 1MHz crystal clock, the processor makes all 4 reads.
Any other ideas? Thanks a lot!
So an update... For more fun, I hooked the 68k up to an FPGA instead of the PC-104 to eliminate the very crude signal timing performance. After doing that, 68k worked fine, even down to a couple Hz. I suppose the processor may be sensitive to irregularities in clock duty cycle.
BTW, after verifying the logic in the FPGA (avoiding tedious wiring of discrete chips), I finally broke down an wired up a version all in discrete logic, with 27256 EEPROM, 6264 SRAM, etc. This FPGA is still in there, but now as a 'chip selected' device for sound, VGA display, PC keyboard input, etc.
68k forever, right??
The CPU may be sensitive to slow rise and fall times on the clock, and certainly glitches on the clock are to be avoided.
