bz
Well, I rather ruled that out when I'd get a poke without it
on. Same thing with my boots. I get a poke when I wear shoes.
The instances do diminish in the summer time but then that's
normal.
Static electricity is worse when the humidity is low. When humidity is
high, even the air can act to discharge the charge.
Yup. What I don't understand is why I don't ground out completely
with the first poke. One of these days, I'm going to remember to
not turn around to lock the car and see if that recharges me. I
know it's a silly notion, but I have to rule out them out, too.
Some things act as capacitors and may need to be discharged more than once.
For example, the picture tube of a TV set. The glass of the tube acts as
the dielectric of a capacitor. When you work on a TV, you must be careful
to discharge the high voltage anode connection on the side of the bell.
After the tube has been discharged, as the glass relaxes and as distant
electric charges make their way to the conductive coating inside the glass,
the picture tube will 'build up' a charge again.
It is wise to leave your grounding strap connected for several minutes
before you start to handle the picture tube.
bz
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
