Hello all at Electronicspoint. I have not posted for a while, I have been busy with GCSE's, electronics and other things.
A few months ago I made an accidental discovery involving a liquid (shall remain nameless due to intellectual property rights, mine) and aluminium, finding that a voltage was produced between them. At the time I did not know about aluminium based electrochemical cells, I googled and it was obvious to me that aluminium had been used before in cells. Upon reading the list of electrolytes used I read over the contents of the liquid carefully. None of them matched, see here. I initiated my test with water, this produced approximately 0.15 volts, wildly off the third of a volt I managed to produce. I started trying other liquids with known chemical ingredients. Upon trying another mixture I found a far more successful 0.5 volts from a single cell. The one thing the liquids both shared was water, this however may not be held responsible as the finding of 0.15 volts shows. One of the mixtures contains alcohol, the other does not, one mixture contains a base and an acid, the other does not. There are no correlating ingredients. Other than water there are no obvious oxidisers. After building several revisions due to electrolyte leakage plaguing the first revisions, I have a stable construction, four cells in series, producing a total of 2 volts.
Compare this to other chemistries and this may seem insignificant, however my mixtures were completely safe. I have been in prolonged skin contact with no effects, I have worn no eye protection either. With the obvious exceptions of ingestion and contact with eyes, my battery has no harmful effect whatsoever.
The most exciting part happened today, upon gathering all the information I could on the electro chemistry I tried to find whether the battery is rechargeable. The battery was connected to an LED for an extended period of time, the voltage dropped from 2.05 volts to 1.97 volts. I applied a reverse voltage across the battery for about thirty seconds, upon testing again with my voltmeter, the voltage had risen to 2.00 volts. I will not jump to conclusions, can anyone give me advice as to how to proceed?
The mixtures are not ones that may be manufactured at home, I only have access to them under certain circumstances which I shall not name for risk of revealing clues.
I would like to find out:
Which chemicals are responsible for reacting with the aluminium?
Is the chemistry rechargeable?
Are there any books that would aid me in the field of aluminium electrochemistry?
Any pointers are appreciated, I have worked hard on this.
