D from BC said:
iic resistivity of pure water is 18.2Mohm cm^2/cm at 25C
Ultrapure water is a great insulator. It's also "not found in the wild"
and takes constant deionization filtration to maintain in an ultrapure
state. If you go putting copper in it, it won't be staying ultrapure.
One of our pulse machines did use it (with stainless steel inner and
outer conductors) as the insulator for a coaxial line about 5 feet in
diameter (outer - inner was about 18 inches as I recall.) Transformer
oil was used for most applications requiring high-voltage and access to
parts - presumably the water gave a better capacitance for the
transmission line in that case (I worked on them, I didn't design them).
From the practical point of view, the string of carbon (or wire-wound)
power resistors (or multiple strings in parallel if need be for power
handling) is simpler to implement, has no leaking fluid potential, and
is often cheaper. Strings of 2-watt resistors inside a vinyl tube (no
doubt not helping with power handling, but making them safer as far as
inadvertent shorting) were a common way to get a high-voltage resistor
without breaking out the big bucks (research budgets are not generally
lavish) for all-in-one piece high voltage resistors. Better cooling can
be had by wiring them into perfboard instead.
