conrad
How does unplugging electrical applicances(loads)
save on electricity in homes? I know a load utilizes current
and consequently produces power. What I don't
follow is that the way current is provided
is not like a battery, so you don't have the
potential for pushing a charge across
a conductor like you would with a battery
(that provides an electron on the anode to
carry back to the cathode). The way I picture
it is, is that you have wiring that current is flowing
through and that connects to a recptacle.
You can control whether current goes to a receptacle
by using a circuit breaker. But even then, you have
just inhibited the flow of current from the receptacle
to the circuit breaker. Up to that point, you still receive
current(as far as how I picture it). Point being that your
current flows from a nearby pole for example to your
home. In which case, you don't have a varying amount of
current being distributed to your home but the way you
use that current to power appliances can vary. But nonetheless
the overall amount is distributed from a nearby powerstation.
And that amount from the powerstation cannot vary. So anything
you don't utilize would be lost. What I am getting at is this,
it would then follow that whether or not you unplug appliances
in hopes of saving on electricity, the overall amount of electricity
that is sent to your home cannot be controlled by you, and
therefore you are not really saving anything on electricity.
Is my view apt or no?
