JosephKK
The only way I can see someone get electrocuted *from the ground* is if
there is an enormous electrical gradient. It would have to be something
like 50V per ft. Which means that the 13kV would be flowing across a gap
about 200 ft wide. Walking or lying at right angles to the gradient
would not result in any PD across the body.
Where to begin to explain? No body dimensions are zero. There are
much higher voltages running around in densely populated areas, up to
330,000 V phase to phase. Any insulation at 50 V/Ft will help, lying
down will not (of course if you are unconscious you may not have
choice as to orientation or body position.).
