El Panel Brighter
Well, as you have learned, they are not very bright. The are most useful as bacloghing for displays in a dark room.
What is your application?
Bob
Manufacturers specify the brightness of E panels at the normal operating conditions. If you want to exceed those parameters then expect to damage the device or significantly reduce its lifespan.
If you want a brighter light, use a brighter source.
