Don Y
I've been designing a "network audio client" (aka "network loudspeaker")
and now have to select a suitable amplifier to use in it.
1) The amplifier's presence is "optional" (e.g., when interfacing
to external equipment via a "line out", the amplifier is
superfluous)
2) The design is intended to support one or two audio channels
(e.g., drive a single speaker -- BTL? -- or a pair WHICH MIGHT
NOT BE IN CLOSE PHYSICAL PROXIMITY!)
3) Everything is PoE powered (though I will support PoE+ as well)
so the power budget is extremely critical.
4) Size is important. E.g., a few cu in for the whole device.
(note the implications on heat dissipation!)
5) "Louder is better" but LOUD CRAP isn't worth the effort
(i.e., trying to get the most GOOD sound -- not the MOST
sound)
6) Any controls need to be available thru software (gain, etc.)
7) Components need to be available in small quantities for
hobbyists, etc. -- though I suspect I could find a middleman
willing to make large buys and sell in smaller quantities
(hardware and software designs will be released as "Open Source")
I've accommodated #1 by putting all of this on a "daughter card".
Currently, the interface to that card is digital (i.e., for a
"line out" version, another card with DACs and buffers would
take its place). Of course, someone can always opt to change
this later...
#2 Could be accommodated with two different daughter cards
("mono" and "stereo"). Or, operating a stereo amp in bridge
mode (with suitable changes in load). A set of "mono"
devices might be used, for example, staggered around a listening
area (e.g., a 7.1 theater system) giving more power to each
device and/or making wiring more practical (run network drops
to each location instead of having to run drops to half of the
stations and "string wire" along a baseboard to the "other"
speaker in each pair).
Besides power budget, #3 also places constraints on how well
behaved the device is when powering up/down -- since power
can/will be applied/removed remotely. Clicks and pops need not
apply! :>
The size requirement in #4 *could* be flexible but impacts the
types of deployments possible. E.g., here, I plan to mount most
of them in 1G Jboxes (possibly using the box itself to help
dissipate heat). This eliminates all of the cosmetic "packaging"
issues.
Sound level and quality (#5) is, of course, a subjective assessment.
For high quality deployments, I imagine the amplifier will be
removed and replaced by something (external?) of much better
caliber. But, when present, it should be "usable" in normal
(i.e., non-teenager!) environments. A two channel device might
take the place of a "table radio". A set of mono devices (e.g.,
the 7.1 setup) could provide a rich home theater experience.
The impact headroom has on that quality becomes a significant
design issue (esp due to #3)
The controls (#6) need to be "remotable". I.e., a "network loudspeaker"
mounted in a ceiling would be impractical to adjust if the controls
were collocated with the speaker. Being able to "tell" the device
what you want and having the device perform that action itself seems
the only practical solution.
Personally, I could skip #7 (<grin>) but that would be a bit selfish
in light of the open nature intended. (building something out of
unobtainium is hardly a good way to promote its use!)
So far, my searches keep bringing me to TI's class D offerings -- though
none seems to be the perfect cherry. And, class D leaves me worrying
about sound quality and RFI (generated) -- esp when the loads aren't
close to the amp (e.g., the two channel case)
Pointers?
Thanks!
--don
superfluous)
sound)
this later...
apply! :>
issues.
Pointers?
Thanks!
--don
