I sent a set of Gerber files from EasyPC v8.0.8 to Advanced Circuits
( http://www.4pcb.com ), and was told that the "dimensions" file
contained improper information ("only two small dashes"). This
resulted in my pcb design being put on "CAM Hold", which delayed its
processing.
I ended up having to create a PDF for them, with a drawing showing a
marked reference point and the dimensions to each side of the PCB
outline from the reference point, so they could make a Gerber
dimensions/outline file, for me, from that.
This was the first time that I had had someone else make boards for
me. This was for a 2-sided board, 9.75" x 2.9375". I did use
4pcb.com's very nice "FreeDFM" check, first, which showed NO errors.
And all of the PDF drawings of the copper layers, silkscreen, and
soldermask layers, which their FreeDFM automatically creates from
uploaded Gerber files and emails back, looked fine.
Using Windows Notepad, I looked in the Gerber "dimensions" file that
EasyPC had created. Here is the whole thing:
%FSLAX23Y23*%
%MOIN*%
G04 EasyPC Gerber Version 8.0.8 Build 2014 *
%ADD10C,0.00100*%
X0Y0D02*
D02*
D10*
X8076Y1105D02*
X9543Y2528*
X9886Y2813*
X9907Y2851*
X9916Y2764*
X9943Y2558*
Y2579D01*
Y2622D02*
Y2696*
X0Y0*
M02*
I'd never seen the inside of a Gerber file, before this, and don't
have a Gerber file viewer (YET). So I don't know if this looks
reasonable, or not. But apparently it's not, or else there was a
problem while transmitting it.
I'm also wondering if maybe there is some setting, within EasyPC, that
I need to change. If not, what could be the problem and what could I
do about it? Anyone? Or maybe it's time to upgrade to EasyPC v10.
Thanks.
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
processing.
%FSLAX23Y23*%
%MOIN*%
%ADD10C,0.00100*%
X0Y0D02*
D02*
D10*
X8076Y1105D02*
X9543Y2528*
X9886Y2813*
X9907Y2851*
X9916Y2764*
X9943Y2558*
Y2579D01*
Y2622D02*
Y2696*
X0Y0*
M02*
Thanks.
- Tom Gootee
