Hi all. Talented amateur here, stage electrician at school 1971 - 74 and have done much DIY electrical work iover the years, including central heating systems. I worked for several years for the residential division of Honeywell Control Systems and wrote many installation and user instructions for heating controls.
I have a Kärcher 520M pressure washer which has given excellent service over the years, but using it to jet a drain problem a few days ago and it stopped working and my wife noticed that much of the power in the house had gone off. The washer has a powerful induction motor.
Our consumer unit is a split system with two RCDs, and the house supply is PME, one of which was off. It reset ok but once the pressure washer was turned on again, off the RCD went. The 13A fuse in the washer's plug did not blow.
A bit of online searching suggested the pump motor's starter capacitor was the likely culprit, a 25ùf device, so I ordered a new one and it came the next day. First time I tried it, the pump twitched into life, but then the power went off again.
It has been suggested that a small water leak between pump and motor could be responsible, but I have been unable to strip the washer down far enough mechanically to investigate, but will persevere. The electrics are pretty well isolated in the control box and there's no obvious way water could have got in and caused an earth leak. I wonder whether the in rush current from the starter capacitor could have triggered an earth leak, but I am reluctant to junk an otherwise serviceable capacitor.
Comments, suggestions much appreciated.
Thanks very much.
Thanks very much.
