DRO Mitutoyo AT11-series; attach connector to cut-off wire.
A while ago I have been given a digital readout system for the lathe
(DRO) from Mitutoyo, with AT11 series linear scales (rulers).
It needs a bit of work done though, mostly because the connectors have
been cut off from the linear scales. After a bit of research on the
net it appears it needs a 6 pin round connector, but the hardest part
is to figure out which wire goes to which pin. I don't have the
original connectors anymore either so I can't work back from them.
Very little info is available on the net.
I was wondering whether anyone in here had any technical information
(esp. w.r.t. wiring the rulers) on the Mitutoyo AT11-N100 and AT11-
N350 scales with 6 pin round connector.
I'd greatly appreciate any help on the subject.
Regards,
Peter Dingemans,
The Netherlands.
Mike Berger
Post this to rec.crafts.metalworking and you'll probably find
someone with the information.
