O
OBones
Hi
How would I go about driving a common source MOSFet configuration (Two N
type) with the output of an Opto Mosfet (N type)
Basically, the schematic would be this:
| D
----- | | G | S
| V -> ||<- | |
| - -||-+ | G | S
| D
But I'm not sure as to how to connect the optically driven mosfet to the
two others.
Here are a bit more details:
What is connected to both D's is an AC signal, and that's the only
"power" source on that side.
When the LED is on in the OptoMosfet, the two Gates must be On so as to
turn the two mosfets On.
When the LED is off in the OptoMosfet, the two Gates must be driven to
zero so as to stop the mosfets.
And finally, if I replace the Two N type mosfets with two P type
mosfets, would that still work? Would the common source configuration
still be valid or would I need to go for a common drain configuration?
Thanks a lot for the help.
Olivier
| D
----- | | G | S
| V -> ||<- | |
| - -||-+ | G | S
| D
two others.
Olivier
