scouselad
I'm designing an electronically-controlled light dimmer circuit based
on one I found at: http://www.edn.com/article/CA46649.html
I'm replacing the SG3524 PWM chip with a PIC16F877A and I intend to
take a digital input from the user and (scale it, then) compare it
with the 0-5V from the op-amp (digitised using the PIC's ADC). As you
can see from the diagram, the PWM signal drives a PNP Darlington
transistor*. However, the SG3524 can provide 100mA of current, whereas
the PWM pin on the PIC can only provide 25mA. (Note that this current
is not only injected into the base; it also feeds through to R1.) So,
do I need some sort of driver between the PIC and the transistor? If
so, what sort of circuit would I need?
*Incidentally, the model used by EDN is no longer available so I
intend to replace it with a BD678 - can anyone advise me if this is a
suitable replacement?
