I have a component question. I am repairing a generator. I have 2 diodes bad. rectifier diodes. Stud type. I have 2 of the same generators, different years. They look identical. Now I pull out the diodes. Try to look up the numbers and don't find much. From what I did find, it appears to be a 20a 600v cathode case diode. Will it be alright if I get a stud diode with the correct amps, voltage, and negative case. Here are the numbers I have off the diode MSC 9118 R2160.
Thanks for the help.
