DIGITALY CONTROLLED RADIO RECEIVER
RealInfo
Hi all
My question is about the structure of a digitally controlled radio like this
http://www.hamradio.com/detail.cfm?pid=H0-010818
From the point of view of the micro controller that controls it .
If I understand well that micro does 3 main things
1> controls the frequency of the PLL that functions as a local oscillator
used by the rf mixer
2> sends the relevant data to the LCD .
3> respnds ti the buttons .
I want to concentrate on the first two .
How the micro controls the PLL so it will produce the exact frequency
that the LCD displays.
And how the micro translates the frequency knob to a chosen frequency .
Elico
Jasen Betts
Hi all
typically the PLL is a VCO which is divided and compared with a fixed
clock, the microcontroller will program clock divider - it may even
use an internal counter to do this. this divided clock is compared
with a reference clock and the difference is fed back to control the VCO
probably some sort of quadrature encoder and a the micro just counts
up or down as the knob is turned.
Tauno Voipio
Hi all
Elico
Many of the current designs are using Direct Digital Synthesis (DDS)
instead of a PLL, though also PLL designs are used. The details of
frequency set-up depend on the frequency generator chip (or chipset)
chosen and the selected frequency generation scheme.
For a primer on DDS, see:
<http://www.analog.com/library/analogDialogue/archives/38-08/dds.html>
There are also links to chip datasheets and app notes for controlling
them.
RealInfo
Hi all
Elico
Many thanks you all
Elico
