I am looking for a replacement for AOD444, a n-channel mosfet in an
inverter
http://www.aosmd.com/web/products/product_display.jsp?displayType=mosfet_part&partnumber=AOD444
www.aosmd.com/pdfs/datasheet/AOD444.pdf
AOD 444 , vds :60v, vgs:20v, id: 12A
I checked digikey.com, but only 2 similar one are available. They are
IPD640N06L G
http://www.infineon.com/dgdl/IPD640...90004&fileId=db3a304412b407950112b42ed0ce4a85
and
MTD3055VL
http://www.fairchildsemi.com/ds/MT/MTD3055VL.pdf
They both look similar to AOD 444, but they are logic level.
QUUESTION
Will it work if i substitute a mosfet (without logic level ) with
another mosfet that has logic level?
Also, i found another similar one ,std12nf06l
http://dkc1.digikey.com/Redirect.as...ne/products/literature/ds/8179/std12nf06l.pdf
The Continuous drain current ID at 25 degree C is the same as aod444.
BUT it is smaller than AOD444 at 100 C.
QUUESTION
When replacing mosfet, do we have to consider the ID at TC=100 degree?
inverter
IPD640N06L G
and
MTD3055VL
QUUESTION
QUUESTION
