SAUHING LEE
I am looking for a replacement for AOD444, a n-channel mosfet in an
inverter
http://www.aosmd.com/web/products/product_display.jsp?displayType=mos...
www.aosmd.com/pdfs/datasheet/AOD444.pdf
AOD 444 , vds :60v, vgs:20v, id: 12A
I checked digikey.com, but only 2 similar one are available. They are
IPD640N06L G
http://www.infineon.com/dgdl/IPD640N06L+G+Rev1.2.pdf?folderId=db3a304...
and
MTD3055VL
http://www.fairchildsemi.com/ds/MT/MTD3055VL.pdf
They both look similar to AOD 444, but they are logic level.
QUUESTION 1
Will it work if i substitute a mosfet (without logic level ) with
another mosfet that has logic level?
Also, i found another similar one ,std12nf06l
http://dkc1.digikey.com/Redirect.aspx?url=http://www.st.com/stonline/...
The Continuous drain current ID at 25 degree C is the same as aod444.
BUT it is smaller than AOD444 at 100 C.
QUUESTION 2
When replacing mosfet, do we have to consider the ID at TC=100
degree?
inverter
IPD640N06L G
and
MTD3055VL
QUUESTION 1
QUUESTION 2
degree?
