John Fields
I can only apologize.
Apology accepted.
Sadly, It's all too easy to fall into the trap of talking down to
one's inferiors.
one's inferiors.
On Thu, 13 Jan 2005 17:41:50 -0600, John Fields
Ridiculous twaddle.
Once again your comprehension problem raises its ugly head.
I think it was Charles Peguy who once said: "He that does not bellow
the Truth when he knows the Truth is the accomplice of liars and
forgers."
I am no such accomplice. I *do* bellow the truth. The "stealth" I
mentioned relates solely to the *means* by which the Truth is
disseminated. I don't compromise by publishing innuendo; I simply
obscure myself as the source, that's all. And even that only to
preserve my liberty and livelihood in this modern era of suppression
and Liberal bigotry.
See above, Bonehead.
Uh-huh...
The change in drop may only be 200mV., but when you're talking about
an initial level of only IRO 650mV., I'd say that amounts to a large
drop alright! It's all relative.
You *do* realize that one diode drop
at room temperature is only just over half a volt, don't you, Junior?
Lectures from someone who doesn't even know how a BJT works, I don't
need.
how's it going John.. see your having a nice day)
keep up the good work.!
i don't remember ever getting involved in this thread, i was justMiles said:Put it out of your mind as a pointless distraction, sonny and get
stuck back into your textbooks. Head down and study, study, study is
the only realistic way to success.
HTH
drop alright! It's all relative. You *do* realize that one diode drop
Consequently, it's not a question of lack of comprehension on my part,
but a lack of clarity on yours.
However, I should have guessed that would be your method of choice
judging from the bob-and-weave tactics you've employed in your earlier
posts.
Well, IME, for the same If, Vf depends on what the diode's made of.
Easy enough to check it out... get yourself a 9V battery, a 20K
rheostat, a silicon junction diode, a Schottky diode, a 0-1mA ammeter
and a 0-1V voltmeter. Making sure you have the rheostat cranked to
the max resistance position, connect everything up like this:
+9V
[R]
|A |
[DUT] [0->1V]
[0->1mA]
-9V
Then, adjust the rheostat to the position required to make the
milliammeter read 1mA, note whether the DUT is the Schottky or not and
write that down along with the voltage indicated by the voltmeter when
the milliammeter reads 1mA. Do the same thing using the remaining
diode and report back to us with what you find, OK?
Before you can determine whether or not someone knows how a BJT works,
you need to know how a diode works. You haven't demonstrated any real
competence in that arena, so I suggest you do the experiment I
described and see what you can learn from it.
Before you start making noises about who knows what about BJTs you
really ought to get that diode theory down.
Ummmm...I would like to point out that the "relative" in most
relevant cases here will mean "with respect to other DC voltages
in the circuit," NOT with respect to the magnitude of the B-E
drop itself. For the purpose of most DC biasing calculations,
f'rinstance, assuming the B-E junction to be a constant drop of
~0.6-0.7V works just fine, thank you very much. You can go
back and refine things if you like, later on, but you'll generally wind
up with results far closer to reality than the accuracy you can
count on in the component values, supply voltage, etc.. So
what's all the hubbub, bub?
Why do I get the impression that the "works and plays well
with others" box was rarely checked on your report card?![]()
On Fri, 14 Jan 2005 10:58:06 -0600, John Fields
[semantics snipped]
More semantics.. Where's the beef??
posts.
Semantics again...
[snip more bilge]
No really??? Goodness me!
+9V
[R]
|A |
[DUT] [0->1V]
[0->1mA]
-9V
I don't have to do this stupid experiment. Any half-competent engineer
will know that the barrier height potential of the Schottky will be
*much* lower than a 'comparable' silicon diode.
You're talking maybe
270mV. Germaniums likewise (but you won't remember germanium diodes,
Junior).
Shall we perform your dumb experiment with other types, too?
How about a back diode? can you get any lower than that?
If I learned anything new from *that* experiment I'd give up
electronics altogether tomorrow.
Now that I've explained it to you you can pretend you knew it all
along?
Here's a little something (Positively Fourth Street) from Bob Dylan
you might identify with: (Pay particular attention to the sixth,
eleventh, and twelfth verses.)
6:
Do you take me for such a fool
To think I'd make contact
With the one who tries to hide
What he don't know to begin with 11:
I wish that for just one time
You could stand inside my shoes
And just for that one moment
I could be you 12:
Yes, I wish that for just one time
You'd know what a drag it is
And yet, "knowing" all that you chose to make this unqualified
statement earlier on?:
"You *do* realize that one diode drop at room temperature is only just
over half a volt, don't you, Junior?"
I'd say that sentence speaks volumes about your competence.
An experiment can't be dumb, [stupid] but the experimenter can.
That's why I suggested that _you_ start with the pot cranked to
maximum resistance.
Hmmm... Where have I heard _this_ before?:
over half a volt, don't you, Junior? "
Ignorance isn't exposed by the use of "foul" language, it's exposed by
posting material full of errors as you are wont to doing.
Also, PKB with that "FOAD" to Jim Thompson in abse, no?
along?
I ain't pretendin' nuthin'. This is all *basic* stuff and nowhere near
even undergrad level.
6:
I could be you 12:
[bafflement]
None of which is applicable here. Thank God they don't write 'em like
that anymore.
I'd say your remark simply shows once again that you either don't
read, or don't understand, what is written for your consumption. (That
much was obvious from your tedious exchanges with Kevin). You ought to
know perfectly well that my earlier comments were in relation to a
typical silicon diode with a Vbe of 0.6-0.7V. Allow me to quote from
an earlier post of mine made 2 days ago:
"Really? So what is it you're taking issue with? Taken as a
generalization for most silicon diodes I can't see real problem with
it."
I thereby made it perfectly clear I was *not* including the more
exotic varieties of diode in my remarks!
So you did a little research on the Web, uh, Junior? Well it's about
time you absorbed something for a change. Keep it up!
maximum resistance.
How very thoughtful. And there was I about to connect it straight
across a lead/acid battery...(forward-biased, of course).
Indeed. So why all this nonsense about Schottkys?
[/QUOTE]Your ignorance is only exceeded by your persistence, I'll grant you
that.
ROTFLMAO!! That's rich, coming from you of all people.
"FOAD" isn't a swear word; it's an acronym containing one. I wouldn't
stoop so low as post the 'F-word' in a public forum.
along?
6:
I could be you 12:
[bafflement]
What a surprise!
that anymore.
A 9V lead-acid battery? Where would you propose to find one of those?
Nonsense? Schottkys _are_ as plain ol' garden variety diodes as
silicon junction diodes are WRT negative resistance characteristics,
but that's hardly the point, the point being that you made the
statement (no matter how you hard you try to slime out of it) that a
diode's Vf is about 0.5V at room temp, which it is _not_ if you're
talking about a silicon junction diode, which we were.
Did you really think the lyrics I posted earlier were from a rap song?
I blame phony, self-important bastards like you who drive them to want
to do _anything_ but be like you. Watch that eleven-year-old...
IKYABWAI? Pretty lame, Bozo!
An interesting picture of you is emerging from this exchange;
basically that of someone who is afraid to say what he really means or
with being associated with having said it. Basically, a coward.
As we say in Texas,
"Tu eres un come mierda."
On Sat, 15 Jan 2005 09:47:38 -0600, John Fields
along?
6:
11:
I could be you
12:
[bafflement]
What a surprise!
that anymore.
I understand allusion perfectly, Junior. What I don't understand is
why some spotty-faced, high-school-reject jerkoff like you would want
to post lyrics from a song that so clearly flags up his own
self-loathing. You're so full of yourself in your postings, yet you
cite self-disparaging lyrics that basically show you up to be the sad,
sorry-assed, sack of s**t loser/loner that you really are. That's
quite an admission in a world-wide public forum!
I appreciate you're only trolling here, Junior, but if you do a little
research on the Web you'll find that such batteries are comprised of a
series of lower value cells. You just place them in series and stick
'em in one box and voila: you have the required voltage.
BTW, I don't appreciate sarchasm from spotty-faced, high school
rejects, so cut the crap and show some respect, boner.
You can't have it both ways, Junior. Let me repost that quote of mine
that you're so fond of citing in this thread:
Now, please tell us which common-or-garden, run-of-the-mill,
general-purpose silicon diode *doesn't* have a drop of "just over half
a volt" at room temperature??
Yes, I do. As is clear for all to see. Sadly, I don't have Kevin
Aylward's degree of persistence, however.
I find it exceedingly tiresome to have to repeat, ad nauseam, the kind
of entry-level basics that my youngest son was acquainted with a good
3 years ago.
Certainly not. I know the song you quoted, but like everything else
Dylon wrote, it's an overvalued crock of s**t. I'd wager that in truth
you get off on the likes of Eminem, 50 Cent, Tupac and Dr. Dre. That's
where you get your dire attitude problem from, IMO.
Why wouldn't anyone want to be successful and erudite? Why wouldn't
anyone want to be able to piss all over jerks like you in debates? Why
wouldn't anyone want to be able to see through the smoke and cut to
the quick?
My youngest (like his siblings) is going to grow up to be just like
his dear old dad - a chip off the old block - whether he likes it or
not. It's for the best. The alternative is too horrific to
contemplate. It's just a tragedy that I can't save him from exposure
to the poisonous, soul-destroying influences of the rap music culture
that you so clearly embrase and embody.
I'm not familiar with that term and I shudder to think what it might
mean, coming from a foul-mouthed young hudlum like you. Kindly
preserve my igorance!
No, I'm simply maintaining my place on the moral high ground.
We don't all live in a free country, Junior. My right to say what I
believe has been proscribed by the stinking British government. Just
think yourself lucky that you're alive and well in a country that's
only too happy for you to sit in front of your dumb TV shows, jerking
off at all those topless models.
There's nothing false about me, Junior.
As we say in Texas,
Does your mommy know you have access to a computer??
Miles Harris said:NOTHING!!!
Come on, you gutless bonehead! Respond and defend your position!
On Sat, 15 Jan 2005 11:39:31 -0600, John Fields
3 years ago.
Dylon wrote,
Why wouldn't anyone want to be able to piss all over jerks like you in debates?
Why wouldn't anyone want to be able to see through the smoke and cut to the quick?
Kindly preserve my igorance!
Just think yourself lucky that you're alive and well in a country that's
NOTHING!!!
With a terminal voltage of about 2.041V,
http://www.tpub.com/content/doe/hdbk1084/css/hdbk1084_24.htm
There's no way you can get 9V out of any number of lead-acid cells no
matter how you choose to arrange them or what kind of a box you put
them in, LOL! Now, you can't get much more basic than batteries, and
you obviously don't know what you're talking about even there, so
you're running at about what so far? Zero for two?
Rather than just handing you the information, I think it would be a
good thing if you got off of your fat, lazy, ass and performed that
little experiment I suggested and then post what you find. I mean,
after that battery fiasco aren't you even interested in finding out
whether what you think you know about diodes is true?
make Schottkys then? said:As usual, you're wrong on all counts and the attitude only _seems_
dire to pukes like you because you're used to people falling for your
crap and not contesting it.
If the price of achieving those goals is winding up with a personality
like yours, I can see why a lot of folks would rather be failures.
They can try if they want to, but I'll just piss back harder.
You're an idiot. You have no idea who I am or what I believe in, and
yet you consider yourself fit to make pronouncements based upon your
opinions, pretty much the same way you've fallen on your face
pretending you have technical skills.
Crappola. All you're doing is posturing, pretending that you're
"above it all".
Yeah, ours was too until we kicked the British government out of here.
There's a lot better porn on the net than there is on TV, I'm sure you
know, and it's not luck that we are where we are. First we had to
kick out the Brits and lose a lot of lives doing that, then we had to
jump into WW1 to _save_ the Brits and then, a few years later jump
into WW2 to save the Brits again. We _all_ lost a lot of lives to
"save the world", and a little luck here and there helped, but it
wasn't _all_ serendipetous.
So you're saying I can't get 9V from a lead-acid battery?? And I'm not
talking about relying on any type of rheostat or voltage-dropper here.
You're saying it's impossible for me to get 9V out of a lead-acid
battery by itself alone? Are you serious?
IOW: "Holy crap! Miles has boxed me into a corner here so rather than
admit to the fact that I was wrong all along I'll try another
diversionary tactic."
Look, Junior, your 'experiment' simply demonstrates that the barrier
height potential of the Schottky is around half the level of a regular
silicon diode. You OTOH seem to think they're the same thing and
therefore interchangeable, presumably. I wonder why they bother to
make Schottkys then? <sigh...>
I'm certainly not used to having my opinions questioned by a
snotty-faced school kid, that's for sure. You gotta lot of nerve,
Junior. Most good folks simply accept what I tell them and go away
wiser for it. Not so in your case, however. :-(
You don't like my personality? Sounds like sour grapes on your part,
Junior.
I haven't seen any evidence of that yet...
I've made a good living from my technical skills over the years,
Junior.
People don't pay you good money for being a bonehead.
Now, isn't it about time you stopped jerking off in front of that computer
and went back to high school?
Certainly not. it's beneath my dignity.
Shame you can't kick them out of *here* as well!
Britain wasn't occupied in either WW so I don't know where you got
that lofty idea from.
And 'you' were quite happy to sit on the
sidelines and twiddle your thumbs until the Nips blew Pearl Harbor all
to hell. If that incident hadn't forced your hand after more than 2
years of inaction, you'd probably have stayed out of WW2 altogether
and left us to get on with it alone.
Yeah, but I'm not talking about cheating and loading the battery down
so hard that its internal resistance drops 3V (if it's a 12V battery).
But, I could be wrong, so what did you have in mind?
The purpose of the experiment is to prove that your statement that the
Vf of a silicon junction ("regular")diode is a little over 0.5V is
wrong. The reason for performing the experiment on a Schottky diode
as well is to show that the Vf of a Schottky is lower than that of a
silicon junction diode. So do the experiment and prove that I'm wrong
and that the Vf of a silicon junction diode _is_ close to 0.5V, or
shut up.
Well, yes. I tend to be critical of blowhard self-proclaimed
purveyors of "Trooth", who do little more than proselytize.
It's not that _I_ like it or dislike it, I do neither. I look on it
as just another manifestation of an ego trying desperately to seem
important.
Selective vision at work...
Well, you may have made a good living, but if you have to ask for help
with writing a verbal description of the internal resistance of a
battery, then I suggest that the quality of your "technical skills"
is suspect.
If they're bigger boneheads than you are and you can talk them into it
they will.
Actually, you're right. This exchange seems to be little more than
mental masturbation, and I _do_ need to get some development work
done, so I think after this post I'll just cut you loose and leave
you to your own devices.
Count me out of that one. We've got enough problems over here without
taking on yours as well. You fix it.
Had we not jumped in the first time you would have been, and there
probably would not have been a Britain to defend the second time.
Well, we preferred to _try_ to remain neutral, but no... somebody
always has to start shit and then we get involved in it because we get
asked to or because we get war declared on us and then everything just
spirals out of control and it turns into a big ol' war.
As far as the Japs are concerned, they attacked us on December 7th of
1941, and we probably would have gone off and just taken care of that
if it hadn't been for Germany declaring war on us a few days later, so
maybe it's lucky for you all that in addition to being attacked by the
Japs, the Germans also declared war on us. We eventually would have
jumped in to help you guys, we always do, but the German action left
us little choice about the timeline. Anyway, that's all water under
the bridge, and what we're _really_ talking about is your technical
incompetence.
Uh-huh... Kind of like you showing me that you've squirrelled away a
lot of currency into a safe deposit box and then me explaining to you
why it's all counterfeit.
As opposed to what? Inorganic brain damage?
5 cells in series, partially-discharged, powering a small transistor
radio.
I've heard of splitting hairs but this is ridiculous, you insolent
young pup. You are saying both diodes are essentially the same and
therefore interchangeable.
I'm saying no way; certainly not for all
applications at the very least.
You want to be careful with those long words, punk; they'll aggravate
your acne.
I don't give a fig for being revered. That's a concern solely for
lonely, lame-ass losers with a fragile sense of self. Ring any bells?
Once again, you misunderstand. That's what comes from listening to too
much rap music. I can't communicate on the same level as young punks
like you; that's all there is too it.
Not at all. They beat a path to my door. I don't even have to
advertise.
Translation: "My ass can't take no mo' whuppin' from this Miles guy! I
need to bail out - and fast!!!"
ROTFLMAO!!!
BTW, if this "development work" you have in mind is to make your dick
bigger, you'll find the Swedes make the best devices. ;->
I must add one point, though: when *your* ass is on
the line, *we* are just as keen to jump in and help you (for what its
worth with what's left of our vastly downsized armed forces). We don't
forget past favors and there's still a lot of affection here for you
bastards.
ROTFLOL! I can't help but like you in a strange kind of way. You
remind me of the son I never had - THANK GOD!!! ;->
Bwahahahahahaha! Nice one, Junior.
