Hang in there Michael, you will succeed with the help of the hugely knowledgable guys helping you. Just be methodical and keep copious notes of the results of your actions.
Regarding the track lifting, maybe up the temperature of your soldering iron and do put some rosin and extra solder on the solder point you are working on
Thanks Bushtech. I'm very grateful indeed for the prospect of assistance in my quest to repair this seemingly un-repairable Denon AVR-1912 E2/EA
Please note there seems to be a discrepancy in the Denon Service Manual for this AVR. Page 168 pinout of IC801 does NOT agree with 801 pinout on page 114 AUDIO_VIDEO UNIT (1/3)
Soldering: I have:
1) an 'HV/K badged 858D which I haven't used much, Three soldering irons:
2). an 'old' 25W.soldering iron with no temp controls. I need a new one as the tip is getting filed down to its point of connection - and won't remove.
3). 20W. 3/16" tip which doesn't seem to hold solder and is reluctant to heat to melting point.
4). Weller 12W.'Micro-Point' which I haven't really experimented with much - it never seems to be large enough.
What is the best iron wattage - presume it should be temperature controllable. I use a bit of sponge in a plastic plant-pot saucer (which I keep wet and covered when not in use.)
5) a 40W. pump-action desoldering iron.
A small non-heated pump-action desoldering tool.
Solder: Bobbin of Lead-Free Silver Solder - it doesn't say whether it has a flux core.
Bobbin of 22swg flux-cored 60/40 Sn/Pb
Flux: A small screw-top tub of 'Powerflow Flux (idela, it says, for lead-free solder. I apply it with wooden tooth-picks. Also Liquid Flux - which I use on re-flowing Computer Mo-Bo's.
Test Equipment:
Meters:
1). The usual old pre digital Analog type
2). an old Thandar TM351 Digital Multimeter - this was 'state of the art' originally.
3). UNI-T UT61E 22000 counts True RMS Multimeter dvm - this has connection for read-out on the Lab Computer
4). HoldPeak HP-9804 this does not automatically switch to a range of Volts/Amps/Ohms/AC/DC but the dial lights!
5). Digital Temperature Meter. I bought this to check the 858D hot air soldering unit.
6). Peak ESR70 Cap. tester.
7). Peak DCA55 Transistor Tester.
8). Oscilloscope: battery operated pocket-sized DS201 pro. Open Source 200Khz bandwidth 1Ms/s sample rate.
9). FeelTech FY3200S Dual Channel Arbitrary Function Signal Generator/Counter with BN5 out/input sockets.
So that's the Lab's equipment. I've listed it just in case it needs printing to help anyone advise on my best use of it!
Right nor the Denon AVR-1912 E2/EA has two horrid problems -
a). reversed polarity - the A+8v. rail reads A-8V. and the A-8V. rail reads A+8V. !!! Why?
b). the A+8v. is arriving at IC801 pin 80 (AVCC) measured at the Cathode of D800 as -7.41V - well, that is, in a way, an improvement for it had been reading much lower! So maybe things are improving if I can get the polarity corrected!
Michael Studio1 UK 11:25GMT
