Delco Radio Wiring (please help)
Jeff
Hello Everyone
I have a 1996 Delco CD player that I would like to put in my '89
truck.
Wiring the power and speakers are not what I really need help with.
What I would like to do is wire up the SCV control. I don't know what
pin or pins to use.
I did get a harness for the radio but it does not come with the 4th
plug. I just want to know what pins I need to use.
Thank you very much for your help... Happy 4th
Jeff
D_Zoot
Jeff,
SCV input to the radio would be pin 16 in connector 2. To help locate
pin 16: OE wiring to pin 15 would have been Dark Green (serial data)
and OE to pin 17 would be Light Blue (RR speaker - )
The radio is calibrated for a 4000 pulse per mile square wave signal.
If you have cruise control on the 89 you can get the 4000ppm VSS at
the cruise module (assuming it's a GM truck!), otherwise you'll have to
find the 4000ppm signal output at the back of the cluster, I don't
recall the pin assignments. You *might* be able to pick VSS up at the
ecm connector, but the ecm might be getting 2000ppm instead of 4,
again, I don't recall.
Jeff
D_Zoot
Thank you very much for the reply. This is the first replies from
all the places that I tried to get the information (THANK YOU).
As to your reply, I don't have the original connector. So can you give
me a better idea of where they are look at the connector from the back
of the radio.
As for connecting the wires from the VSS I will have to splice in to
the wires from the cluster or near the ECM. I will check my service
book, it might be better for me to tap into the wires near the ECM.
I am getting another radio to rework. So I am looking forward to
putting them in my vehicles.
Jeff
D_Zoot
Jeff,
Looking at the back of the radio you'll see what looks like a group of
4 connectors toward the RH side, and a single connector toward the LH
side. The single is for external devices such as an outboard tape
player, so ignore that one.
The other that appears to be a group of 4 is actually two, but the
connector keys make it look like 4 (and some aftermarket wiring kits
use 4 seperate plugs instead of two keyed connectors). The upper row
is connector C1, the lower row is C2
The upper row, C1, contains power, ground, backlighting and front
speaker wiring. The lower row, C2, is rear speaker wiring, VSS and
serial data.
Lower row C2: There are six pins in a row, the connector key (skips
one pin) and then four more pins. Starting at the outside terminal,
the first six pins terminals are numbered 11 to 16, then the key
(skipped pin) then 17 to 20 for the last 4. The vss pin you need is
16, so it will be at the end of the row of six, right next to the key.
Jeff
Thank you for the information. It it is where I thought it was. So I
take it that only one wire is needed for this to work.
At first I did not see that the ends of the locations were marked. Till
after the second reply that you sent.
I don't for see any issues, but I hope that you don't mine if I email
you if I run into a problem.
I am still waiting for some parts. So I will try to connect them in a
few weeks.
Thank you,
Jeff
D_Zoot
Jeff,
Yup, just the one wire, the VSS high circuit. VSS low, or signal
return, just runs on the common ground.
Glad I could help. Feel free to email me, but use dzoot at yahoo
com instead.
Regards,
Jeff
Thank you so much for your help (no one else helped).
I will let you know how it turns out when I try it.
Take care,
Jeff
