Philip Pemberton
I'm designing a simple (ha!) digital oscilloscope that should theoretically
be able to sample up to 80MHz with two A/D converters (giving an effective
frequency of around 160 MHz). I'd also like to design this device so I can
expand it with more converters later on (up to four). What I need to know is
how to delay a logic signal (the /SAMPLE line) so that it's 90 degrees out of
phase. Then I need another two in addition to that - 180deg and 270deg. The
signal needs to be as close to 50% as possible. How could I do this? None of
my textbooks seem to cover this sort of thing.
The idea is that I'll have multiple ADCs sampling at different times, one
after the other. The data will end up in a FIFO, which will then be read by
the PC via the ISA bus.
I'm also going to need a programmable clock divider that can provide
various frequencies to the ADCs. I guess this would be best done with a
counter and a multiplexer?
Thanks.
Thanks.
