Sir KTW . . . . . . .
You sez. . . . . . . . . Just on my way out the door for the day but I'll get back at this later tonight and tomorrow. . . . . . . . .
( Using my best quizzical foreign accent . . . . .where you go ?
where you gooooo ? ? ? )
Answering your very last question first . . . .
I think that FOR367.E is probably going to be a low power 100 ma scr or possibly a unijunction transistor.
I ran into the numbering protocol prefix of "FOR" about 30 years ago and it was a Toshiba product origin and is probably obsolete now.
You sez . . . . . . . . . .I have all but one of the components identified . . . . . . . . . .
- WHAAAAT ! . . . . Does that mean that you have even got the number for the mystery "epoxy clad" 16 pin IC ?
Let’s just start up again . . . . and I know that you have only the bare board, less the motor mounted on the unit, and a three pin connector that would be
going to the speed pot on the unit . . . .also, the saw mounted power switch.
Lets just utilize a 100 watt incandescent bulb in a table lamp to substitute for your motor . . . . plus . . . that way you will also get a visual display at no extra
charge . . . you like fries with that ?
I'm pulling out my redraw of the pcb with its foil side and the component side to its right . . . . . and that was being at the ready months ago.
I transferred a couple of components across the board, for referencing as a visual overlay, in comparison of the foil side .
Boards Initial . . . . POINTS OF INTEREST:
At the very top of the board are the AC power input and the jig saws universal motor.
The YELLOW line bordering is indicating the AC power line “ HOT “ portion of the board, while the lower portion of the board is AC
line isolated, by use of the
RED power transformer.
The
BLUE rectangle is the drive signal optical isolator which feeds the gate of the POWER control semi mounted on the heat sink.
Its bottom half contains the driven LED while the top half contains the photo detection portion.
To the left is a smaller rectangular
PINK 4 pin optical isolator.
Its LED portion is on the top while its photo detection portion is on the bottom.
The power loop of the motor drive circuitry has a 1/2 ohm power resistor (physically just above) inserted in series such that varying motor load conditions
can be fed back thru the
PINK optical isolator for PWM correction for the motor control circuitry at the bottom portion of the board..
Info preparation . . . . PRIOR TO INITIAL TROUBLESHOOTING:
We need preliminary info related to the inter wiring of this PCB to its jig saw mounted components.
Check the power switch and see if it doesn’t connect into my two marked in
BROWN ovals.
If so, then we merely need a jumper clip between them to simulate a closed switch, and being able to leave the switch on the saw.
- Get the part numbers from the PINK and BLUE optical isolators.
- Get the part number of the A.C. POWER SWITCHING semiconductor on the heat sink, so that I can relate to its required gate drive level.
Find the end to end resistance of the speed control pot on the saw, if it doesn’t pull easily, we can use another like value trim pot at the unit or
use two half value resistors in series, to simulate a mid-speed adjustment.
Thassssit . . .for now . . . .
ADDENDA:
I had forgotten your second photo of the board . . . so that is giving us a speed control pot and the switch already connected to the board . . .so disregard those prior queries.
With the only mystery nearby, being the ORANGE connector and its pins and what they connect to on the saw . . . .possibly a tachometer function of motor speed ?
PAIRED PCB SIDES . . . . . .
73's de Edd
