I'm not sure if the saw was being pushed to the limits but that connecting rod or aluminum link arm is attached to a very heavy weight, you can see it at the bottom of the picture.
The arm broke so I'm thinking without all that extra weight the motor is running wild.
He said it was running wide open and couldn't be controlled.
I can't do much more until he decides to repair or replace the arm.
Did the electronics cause the breakage or is it the broken arm that is the cause for the failure?Not sure yet.
http://www.ebay.ca/itm/Craftsman-Co...f9643e&pid=100011&rk=1&rkt=10&sd=151967249890
