If you still want to do three supplies here is how you would emulated a 2P4T switch with 3 DPDT
Switches from top to bottom, left to right...
Switch one when in the up position would be circuit one
Switch one in the bottom position and switch two in the up would be circuit two
Switch one in the bottom position and switch two in the bottom position while switch three is in the up position for circuit three
Switch one in the bottom position and switch two in the bottom position while switch three is in the down position for circuit four
Again fool proof switching only one circuit is on at any given time... Although I would probably go with a variable as has been suggested or even just use a 1P4T on just the outputs as suggested, not a huge waste to have them all on at once...
