Platforms
Content
you mean I have to use 4 potentiometer and adjust them in proper position to get 5V, V , 9V and 12V respectively at the outputt ? Or replaceed it with fixed value resistor ?
Lateset sketch. Is it ok ?
This was suggested by @CocaCola. I also not sure. It means Double pole 4 Throw.?? Got such switch ?
I got it. It's a 2 gang 4 position rotary switch. I don't think you can buy high current contact. This was only use for low voltage signal selection. I think this is the one that that short first the adjacent contacts before breaking the connection and make another contact connection. This is no good for switching output voltage.
Big mistake. Your using 2 separate DPDT and both output tied together. In either switch position upper switch output ( +5V or 6V) will short lower switch output ( 9V or 12V ). Your fixed voltage regulator will be damage together with your load.
Avoid using switch on Vin. Tie them together and and only fixed regulator have output connection will consume current. Other fixed regulator will not consume dc current even its Vin was tied together with other Vin.
You have to connect ground of all ic regulators. It's safer this way than let it float.
I forgot to place a diode that connect to Vin and Vout. This is to protect the IC regulator. Connect diode in such a way that diode symbol pointing to Vin.
