The original text shown by
@Audioguru specifically asks: Which
approximate DC voltage can you measure in figures A, B and C
Therefore the voltage drop across the diode seems to be assumed as negligible. The task is to determine the peak voltage across the capacitor (as compared to the rms voltage given as the transformer's output).
Also polarity has to be observed as the image shows Uab = ? which means voltage between points A (positive) and B (negative). We run here a bit into the difference between the German (European?) way of labeling voltages and the American way.
Germans use a defined direction from '+' to '-', regularly shown as arrows on the schematic or indicated as subscript as in this case. We assume a positive voltage between points A (+) and B (-). Then we compute the value and the result may be Uab < 0 V which means that Point A is actually negative with respect to point B.
Is this right? If not need help.
With respect to above statements by others and me, your answer is partially right, but incomplete. You need to state the polarity together with the absolute value of the voltage.
