D from BC
I'm trying to find the breakdown V for
0.0028 inches of PTFE (teflon) and 0.004 inches (~100um) of Kapton.
D said:I'm trying to find the breakdown V for
Textbook value for PTFE aka TFE aka Teflon is 480 volts per milli-
inch,
and for polyimide/Kapton is 560 volts per milli-inch.
That assumes pure material, clean surfaces, and no conduction
enhancement from ambient light...
This data, from _The_Practicing_Scientist's_Handbook_, Moses, Alfred
J.,
1978 edition...
inch,
J.,
1978 edition...
It depends on what you're measuring, or require.
For FEP (Kapton), Dupont book breakdown is over 4KV/mil (170KV/mm),
but life test data to IEC343 (that includes corona resistance) at
10,000 hrs is measured in the 100s of volts/mil.
RL
Huh.. That's wayyyy different than what's on the link that Joerg
provided.
http://zodiaq.fr/Kapton/en_US/assets/downloads/pdf/CR_H-54506-1.pdf
Table 2
Kapton Type 150 FCR Polyimide film 1.5 mil : 4400V/mil
Table 1
Kapton Type 100 CR Polyimide Film 1mil: 7400V/mil
I supppose it depends on the type of polyimide.
Perhaps the withstand test is differant.
According to (blows dust off book :O === ***)
Reference Data for Engineers 1993
Polyimide: 570 V/mil << Not far from your book.
However..
On ebay item 180431395463 Kapton film
1mil Kapton + 1.4 mil silicone adhesive has breakdown at 6000V !
Ebay item 330275429870
1mil Kapton + 2mil mil silicone adhesive has breakdown at 7500V!
Either silicone adhesive has an impressive breakdown or the Kapton
breakdown is higher than the polyimide spec in text books.
JosephKK said:DO NOT confuse nor conflate breakdown ratings with operational ratings.
Breakdown ratings are typically 8 to 10 (or more) times higher than
operating ratings. This applies to most dielectrics whether used for
insulation or to build capacitors.
D said:That's what happened. I went for the short term spec (V breakdown). When
I should be looking at the long term spec (hours to insulator
deterioration by corona).
The text books list operational.
