Why do you think it should be?
The same reason audio CDs used linear-PCM video instead of compressed
MP3s. MP3 and other compressed formats are inferior in quality to the
uncompressed linear-PCM.
Just as linear-PCM audio is better than MP3s, linear-PCM video is
better than MPEG video, VC-1 -- or other compressed -- video.
IMHO, VC-1 is even worse than MPEG
What advantage would it bring?
It wouldn't have those nasty "jaggies" associated with VC-1 or other
compressed video
What costs (either in actual $ costs or performance) would using
linear PCM require?
I agree, linear-PCM video would be more expensive but it wouldn't have
those annoying artifacts that occur in compressed video formats.
The lasers required would have to be of shorter wavelength than those
used in the writing and reading of conventional DVDs. The wavelength
should be 400 nm since thats the "sweet spot" between the advantages of
short wavelengths [i.e. less physical space on disc required] and the
hazards of ionizing UV radiation. 400 nm is around the shortest
wavelength of non-ionizing UV light.
In addition, the disc would have to be somewhat bigger -- around the
size of 33-speed phonos -- to accomodate the large data size required
for linear-PCM video.
I really don't see this as a major hurdle. What makes it so difficult
for the digital video industries to design the above [i.e. 400 nm
recording/playback lasers, optical discs the size of 33-speed phonos,
and uncompressed linear-PCM video]?
How many bits do you think are contained within each
"pixel"? What do you think the word "pixel" means, and
how is it distinguished from "sample" in the context of
digital imaging?
A "pixel" is *definitely* digital. A "sample" can be analog or digital.
If you divide 1,411,200 by 44,100, what number do you
get?
32
What is the significance of this number?
The bit-rate divided by the sample-rate. What else?
Answer the above questions, and then you'll have your own
answer to this one.
Why are you so hung up on "linear PCM"
as opposed to any of several hundred (at least) other possible
encoding schemes?
Because -- as I said before -- I don't like the annoying artifacts that
occur in compressed video formats. Those nasty pixelations associated
with VC-1 -- and other compressed -- video just make me gag.
http://en.wikipedia.org/wiki/VC1
The only compressions I am okay with are WMA^ and the *real* WMV I
described in the following threads:
1.
http://groups.google.com/group/micr...aa56d?lnk=st&q=&rnum=4&hl=en#4416c0283edaa56d
2.
http://groups.google.com/group/comp...a2396?lnk=st&q=&rnum=3&hl=en#afc33183826a2396
The *real* WMV should have the sampling rates and progressive
resolution [pixel X pixel] of the best quality video signal currently
existing. In addition, the WMV's sample rates and pixelXpixel format
should be exactly the same as the linear-PCM signal it was prior to
compression. As for the color-depth [in "bit-resolution"], decrease it
all you want and I still won't mind. In fact I am interested in seeing
how a movie would look if the WMV's color-depth is reduced so much that
the file-size is just 1-bit [regardless of how long the movie is]. But
don't you dare decrease the pixel resolution or sample rate, do so and
you'll find my vomit all around the room.
^The WMA should be monoaural and its sample rate should at least 44.1
khz which should also be the same sample rate of the signal when it was
in linear-PCM prior to compression. I don't mind if the WMA's
bit-resolution is compressed so much that the file size falls to just
1-bit [no matter how long the audio is]. Just keep it monoaural and
don't change the sample rate.
