Joerg
Jeff said:I beg to differ. Although most of the stuff I work with is rated from
0 to 70C, reality has a way of exceeding the specifications. For
example, realistic automotive temperature spec is -40C to about 100C
(or more). Engine compartments get very hot.
And some automotive engineers should have their head examined. On one
car a module that controlled some stuff in the engine was literally
mounted on top of the engine. Sometiems on hot days the van would refuse
to start ...
The starter on my wife's Corolla just died. Where did they put it?
Between intake manifold and engine! Unreachable, and gets hot there.
<http://en.wikipedia.org/wiki/Operating_temperature>
Recently, we attached a disposable temperature data logger into an
aluminum radio case and let it run for most of salmon season. It went
well over 100C for extended periods when the sun was shining directly
on the case. The vessel owner also complained that his iPod blew up
when left sitting on the top of the same radio. He blamed RF from the
radio, but it was more likely fried by excessive heating.
Incidentally, when I did an autopsy on the radio, most of the screws
had rattled loose. I should have also attached a vibration and
accelerometer data logger.
I was taught very early on that eveything on a boat must be nicely
strapped in and will corrode away in no time. And that stainless doesn't
really mean stainless.
Clever design. Wrap the handle with duct tape. Most such things are
designed for a specific useful life. I suspect (but can't prove) that
research has been performed into reducing the life of plastics under
the guise of having the plastic break down in the landfill. While it
seems a worthy area of research, I suspect that such plastics would
also deteriorate before they reach the landfill. A modest example is
the simulated rubber coating used to simulate a real rubber handle on
some hand held tools (e.g. Sears IR thermometer) and your shovel. It
is designed to turn to sticky mush after about 3-4 years, which is
just about right to insure that none are returned under warranty. I
found that ordinary rubbing alcohol does a tolerable job of removing
the sticky goo without affecting the underlying plastic (usually ABS).
This one is soft goo stuff all through :-(
I've seen similar controlled failure designs in the selection of
electrolytic capacitor voltage ratings and power transistor thermal
cycle calculations. It's fairly easy to predict the onset of such
component failures.
What design review? I don't want to go into excessive detail, but
basically the design was purchased from a consultant in India and
rushed into manufacture without adequate testing. ...
Ah, a design from Outsourcia
... First to market and
cost were the overriding concerns. There were plenty of other things
wrong with it. I was sweating blood because the independent
certification lab was complaining that they couldn't make it pass Part
15 Class A without major modifications. My job was to make these
major modifications, but not change anything, since the product was
being manufactured and stockpiled pending approval. Other engineers
working on the device used this as an opportunity to fix a few things,
which required my approval since it affected the type certification.
That made me effectively in charge of coordinating everything and
guaranteed that I would be blamed if anything went wrong. The BFC fix
was added under my watch. Things went amazingly smoothly. The
certification lab was able to generate the required FCC paperwork.
Changes were made that didn't involve a PCB revision. There was some
grumbling over the necessary rework. No real problems until the RJ45
arcing problem appeared.
That's one mistake I haven't made since. It's an open invitation for
abuse as I learned the hard way. However, I created my own problem. I
could have said "it's not my job" and let someone else handle it. I
was thinking that I could play hero and impress management
sufficiently to get more work from the company. That didn't happen.
If someone insists on fixed but I either insist on cast-in-concrete
specs plus change-order procedure, or decline. Since neither is desired
by clients it's all by the hour for me.
